Calling all heat masters, engineers, braniacs, and anyone.
On my biomass furnace, I have the option of running just one auger/burn pot or two.
The manufacturere shared the programmed feed table with me. I've been tweaking and playing to get more heat like we all do. I've come across a scenario that I'd just like to have some validation from somebody on as I'm not sure of the logic here.
Please keep in mind the following feedrates are calculations based off of using medium sized kernal corn. I burn various mixed ratios of corn and pellets.
One pot on feed #4 equals 8.6lbs per hour
Two pots of feed #3 equals 10.9lbs per hour TOTAL or 5.45lbs per hour per pot
I keep a k-type thermocouple fixed about 6" in front of the exchange tubes inside the plenum. This is fixed and never moves.
With one pot on #4 I see air temperatures averaging 192*F with distribution fan on high.
With two pots on #3 I see air temperatures averaging 187*F with distribution fan on high.
So there is where I'm looking for the logic. Why do I see essentially the same kind of heat output burning more than 2lbs per hour less in one pot?
Yes. It's a BEAST
