What stoves (companies or individual models) seem to be the least reliable/trouble prone?
Former stove companies included...
Backwoods Savage said:I'm not sure stating different manufacturers as having bad stoves will accomplish anything except to rile up some tempers and that is not good. Why not turn your thread around and ask about favorable manufacturers? Positive beats the negative in most cases.
richg said:Backwoods Savage said:I'm not sure stating different manufacturers as having bad stoves will accomplish anything except to rile up some tempers and that is not good. Why not turn your thread around and ask about favorable manufacturers? Positive beats the negative in most cases.
Very well said Dennis.
Wood Duck said:My answer would be that I have not had any problems with my Lopi, so I assume Lopis are trouble free. The problem is that like most people on the list I have only had one stove. Probably a few have owned two or even three stoves, but how many of us can speak with any authority on which brand is best. All you'll get is some people saying they like their stoves and others saying they have had problems. Not very scientific.
I'd try reading through the old threads in the Hearth room, or search for the manufacturer you're interested in and read the threads about that stove maker. For me the choice was limited to the brands carried by the local stove shop.
OldManGeorge said:On the other hand, my Quadrafire Isle Royale (also circa 2008) has been a great stove from day one. It's a workhorse in every way. It's a great stove when it works. And it ALWAYS works.
eclecticcottage said:Wood Duck said:The only thing with the Republic, and it's been since day one, I think the door latching system sucks. We keep needing to retighten the handle. I'm going to have the dealer check it out in the spring when they do the cleaning (which is why I'll have them do the cleaning, so if there's any problems they can take care of it then).
Also, on both stoves with a blower. The blower rattles. The tabs are where they are supposed to be on the wood stove blower, the gas stove blower is pretty hard to access but it appears to be mounted correctly. They have both done it since day 1 and the Dv stove is over 10 years old.
Treacherous said:I wonder if the Republic door latch is the same as the Endeavor? I've only had to adjust mine one time.
I've had a little rattle with blower as well but pretty much eliminated it with a few washers I used as shims on the front corners of the blower.
Ya, they use the same latch on all their stoves and inserts as far as I know. They have a good, simple design and rarely need adjustment, when they do, it's often time for a gasket replacement anyway.eclecticcottage said:Wood Duck said:The only thing with the Republic, and it's been since day one, I think the door latching system sucks. We keep needing to retighten the handle. I'm going to have the dealer check it out in the spring when they do the cleaning (which is why I'll have them do the cleaning, so if there's any problems they can take care of it then).
webby3650 said:Treacherous said:I wonder if the Republic door latch is the same as the Endeavor? I've only had to adjust mine one time.
Hmmmm...ours gets loose at least every other week enough to need to be tightened again. It's loose enough at that point to open with one finger, and it will drop back to the "closed" position when left open on it's own. We also get "dirty glass" along the side where the latch is, about 1/2-1" wide. Only there. I wonder what's up with our door....
eclecticcottage said:It sounds like it's not put together correctly or something is worn out. A lot of the ones that I have worked on won't come loose, the nut comes off but the latch won't move for nothing. Better get that looked at.webby3650 said:Treacherous said:I wonder if the Republic door latch is the same as the Endeavor? I've only had to adjust mine one time.
webby3650 said:It sounds like it's not put together correctly or something is worn out. A lot of the ones that I have worked on won't come loose, the nut comes off but the latch won't move for nothing. Better get that looked at.
RNLA said:MC of 18-20% It would be hard for someone here to get that low..
Treacherous said:Pretty windy and dry over in Kittitas Co... it's been easy to get low teens in my Douglas Fir.
