Dont know if its possible but anyway to bypass the autoclean feature on an AE. House cools off too much during shutdown sometimes, especially when extremely cold out. It would be nice to have stove clean when it is convenient for us.
pelletkrzd said:I thought about that but I dont think it would work. The stove would still go into shutdown mode since it is electronically controlled. The air would decrease, pellets would stop being dropped and eventually it would relight. I think everything would remain the same with the exception of not dumping the pot. It would be nice to have a switch or button that you could just hit when it was convenient for you say like when leaving for work or before going to bed. Not bad when temps are above 25 and wind not blowing. But with the cold snaps we had this winter house was a little chilly at times, after a shutdown.
FordMastertech said:If the stove doesn't get the feed back from the burn pot ash dump motor sensor it will just shut the stove down and not relight. Running it in in softwood pellet setting will give you the longest amount of burn time before it takes a dump. LOL
Motor rotation which should be burn pot floor movement if everything is working correctly. It is basically just a on off micro switch that rides on a cam on the motors shaft leverSmokeyTheBear said:FordMastertech said:If the stove doesn't get the feed back from the burn pot ash dump motor sensor it will just shut the stove down and not relight. Running it in in softwood pellet setting will give you the longest amount of burn time before it takes a dump. LOL
What is it that the sensor is sensing?
FordMastertech said:Motor rotation which should be burn pot floor movement if everything is working correctly.SmokeyTheBear said:FordMastertech said:If the stove doesn't get the feed back from the burn pot ash dump motor sensor it will just shut the stove down and not relight. Running it in in softwood pellet setting will give you the longest amount of burn time before it takes a dump. LOL
FordMastertech said:Yes but the stove will shut down just the same.
pelletkrzd said:thanks for all the input.....I didnt think it was realistic but figured I ask.
Totally different stoves with different operating voltages and types of voltage, old MT Vernon stove is AC new MT Vernon AE stove is DC for just one example except for the AE's igniter, it still uses AC voltage.SmokeyTheBear said:pelletkrzd said:thanks for all the input.....I didnt think it was realistic but figured I ask.
The next possible option I can think of is to see exactly what the difference is between the AE controller and the Non AE controller. Maybe a swap out depending upon shoulder/non shoulder season.
FordMastertech said:Totally different stoves with different operating voltages and types of voltage, old MT Vernon stove is AC new MT Vernon AE stove is DC for just one example except for the AE's igniter, it still uses AC voltage.SmokeyTheBear said:pelletkrzd said:thanks for all the input.....I didnt think it was realistic but figured I ask.
If the house cools off that much between start up and auto clean cycles it's not the stoves fault it's a house envelope issue.
Anything can be done but is it worth it for the little amount you will gain. I find on my AE insert from shut down, dump and to relight takes 10 minutes or so but if you take the amount of time from full heat output before shut down to full heat output after dumping and relighting it's more like 30 minutes. My house will not loose that mush heat in 30 minutes unless it's way below 0 and there are strong winds.SmokeyTheBear said:FordMastertech said:Totally different stoves with different operating voltages and types of voltage, old MT Vernon stove is AC new MT Vernon AE stove is DC for just one example except for the AE's igniter, it still uses AC voltage.SmokeyTheBear said:pelletkrzd said:thanks for all the input.....I didnt think it was realistic but figured I ask.
AC to DC conversion and voltage matching isn't really an obstacle just a minor impediment.
But I do agree on the house envelope as likely being the real issue, but that also isn't a non controllable variable. A little application of permanent pellets can go a long way to correcting that. You can spend your heating $$$ in many ways.
