Hello, everyone.
I have been searching the forums for a while now and cant seem to find an answer to my problem. One thread started down the road only to eventually end up with a dead end. I have an older Mt Vernon stove that has recently acquired some problems. I just replaced the convection and combustion motors due to squeaky bearings and now I have a new problem I cant seem to figure out. When the stove is started I can use the heat adjustment knob to change the output at start up. I can hear the different tones in the exhaust fan when turning it from low to quad. However when the stove is at temp and the convection blower turns on it seems to not matter what the knob is turned to the fan blows at a constant speed, most likely low or medium if i compare it to previous runs. It doesn't really blow much heat. I did check the fan to see if maybe it had gone bad but it blew on quad/high when plugged directly into a wall socket. So i know its not the issue. Could there be a wiring issue here with this fan. It had worked before however the new fan came with an extra wire. I connected the white and black ones to respected terminals and left the red one grounded to the stove.
Thanks
Thanks
