Too dark out now, but I'll try to get a picture tomorrow. The steel is attached with pole barn screws.Nice racks, your call on the blocks.
Is the metal roofing attached ? if so a close up pic would be nice to share.
I think I'll try blocks. Think another problem is that the racks are on a concrete pad. The rain splashes up.Could you put them on 8" cinder blocks? Or maybe even old railroad ties if accessible to any?? Just a suggestion... I raised some of my stacks that are in the timber off of the ground with fallen trees and seems to stay dry during the snow or rain. IMO
Thank you. The concrete pad use to hold dog kennels and is pitched towards the grass.Getting them off the concrete a little will help with keeping the bottom ones dry and let more airflow. Nice racks, looks like a great setup.
As for cost, I want to say they were around $26. Was wondering about raising them to. I will be doing it, but our snow depth can be up to knee deep at times. Raising them with blocks will get more airflow though.From reading a lot of threads since i first joined, it seems that the general consensus is that snow/rain only makes the wood superficially wet and so wouldn't raising your racks be more work than necessary?? As ana side, how much does one of your racks cost to build....I would love some of them in my yard.....great work. Congrats!
Ahhh. Like one had said, maybe cut railroad ties? ThanksDon't put your blocks up so snow can get in the holes, I did this with my shed to get my shed off the ground and the snow melted and the water froze which cracked them so now I have to replace all the blocks. Just a little food for thought.
How I attached the steel.Nice racks, your call on the blocks.
I think I did it right, left enough room for airflow and can fit a wheelbarrow in between to load/unload. Steel can can easily be taken off.Now that's a smart cover. No need to restack into shed either.
Thank you. Was perplexed by the discoloration of the bottom rows.Very nice setup you have! Just an FYI I have my racks on 8 inch blocks that are placed on the ground and covered with metal. Even with an overhang and no real splashing the bottom rows of wood still do the same as yours.
Chair is facing southI am perplexed by the discoloration of the bottom rows.
Recent thread here "bottom of the stack blues" includes my thoughts about thermal mass of the woodpile pumping water vapor out of the ground from under the stacks - into the rows at the bottom.
But here you got a water impermeable layer of concrete between your wood and ground water, but you got bottom of the stack blues anyway.
Is the brown chaise lounge on the back porch in post one facing more or less due South?
Blocks under the racks will help, but that isn't the whole story at least at my house.
My first drying racks from last spring. Looks like the snow got the bottom 1/4 a little wet, normal? Should I raise them up on 10" blocks this year? View attachment 176424 View attachment 176426
There is only 1.75 inches between the steel and the parallel 2 x 4s. We had 14" of heavy wet snow one storm. The steel bowed but didn't crease. I'm going to add some 2 x 4 crossmembers this spring for more support. Not attached to the steel, just below it.Wow, that is really neat set up. No stinking tarps to fight with. Question: does the steel bend from the weight of the snow ?
