Need Harman P68 help
showlow2u
1
show low az.
I have a p68 harman and I purchased a new auger motor now the manual does not show which screws to undue for the replacement I looked on the internet but could not find anything now I stumbled across your sight and signed up hoping I could find additional information. Just hate to call the repairman every time stove dosent start. I welcome all help my part harman auguer motor p68 part 9062520 a1106t harmon auguer motor.
Thanks Mod for correcting the title!
Now, let's have some fun and stay warm!
How your stove works - The facts are pretty straightforward, but how you get people to properly interpret the facts is the hard part. It's your toy, run it the way you want as long as you understand what's going on behind the scenes! Everything noted below is based on me seeing what the stove is doing via the Harman diagnostic tool during the various operation methods. I get to see feed rates, max feed rates, current ESP temps, ESP set temps, room sensor temperatures, room sensor target temperatures, knob positions, switch positions, etc.
Started a new thread for your questions so that they get more targeted responses.
Reactions: pinetop12
If you go to Harman's site and take a look at the service parts blow ups it should help you get an idea of the motor auger assembly for starters. Not a very hard project. Removal of shields is the first thing and probably moving the stove out for easier access.
There is a 7/16 hex screw on the back side of the assembly. Loosen that and pull the whole motor off. Disconnect the wires. You have to swap over some of the hardware to the new motor from the old then reinstall it.
Reactions: bags
