Hello,
Looking for any help or knowledge as I’m inexperienced. I have a Kalamazoo combination wood and oil forced air furnace. When I get a wood fire going at any point when I open the firebox door to add wood the smoke will come billowing out into the basement. Maybe this is proper function but I find that hard to believe. There are two separate “dampers”, one as the smoke leaves the firebox to the chimney with the little lever and the other is a flapper at the start of the straight section of chimney. I’ve attached pictures for reference. I have tried adjusting them with no luck. If anyone could give a bit of help or explanation it would be greatly appreciated, I’m open to learning just haven’t been able to find much.
