Hey guys,
Finally getting around to installing a new class A chimney and hearth pad and I'm looking for advice and tips from the pros. My initial thought was to begin with the hearth pad. My wife and I have picked out some porcelain tile and I made a cardboard template. I was going to take out the laminate flooring and tile straight to the concrete underneath. Ideally, I wanted the hearth pad to end at the edge of the one wall and not stick out past it as I don't think aesthetically that looks as good. Planning on going with a BK King so I read the manual and measured clearances and sketched where the stove would sit. Then I realized I have a problem.
The house has an existing chimney and chimney pipe (behind a chase in upstairs bedroom) but the old stove pipe and stove were removed. It appears to me that the owner then boarded up the ceiling (see newer colored wood in floor compared to old) and then installed ductwork directly underneath it (crap!) and then framed around that with the bulk head. So.......I cut a small hole in the ceiling so I could see what was up there. It looks to me like I'm going to have to install the ceiling support box where that hole is and build up from there. This means going straight up through the ceiling I will come out in the bedroom NEXT to the existing chase so an offset is needed. My question is, can you run 45's in triple wall? From the stove I would go straight up to ceiling support with stove pipe, then I would have to go up a short distance with triple wall, 45 over, run another small distance, and then 45 again back up into existing chase. This means I will have to cut out part of chase and reframe around the chimney. I plan on removing old pipe and chimney. My thought was to open entire side of the chase to access it all. Other question I have, where stove sits is not DIRECTLY under the ceiling support box hole. Should I move the stove such that it is a straight shot? This would mean moving the stove further away from the walls and in turn, means a larger hearth pad. Thoughts?
Always appreciate the help on here guys. Hopefully you can get an idea from the pics. Thanks!
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193608-147a67c5a277ad2546dd19dc955d190d.jpg?hash=JWw1aERxmQ)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193602-7d90ddafa1999c19494673a470722259.jpg?hash=oDsBwWXVyS)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193603-4eda8032bd56ce959bc53b330717cde6.jpg?hash=tqubyB6J-s)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193604-70c07f1d759edd1bb64eb5ceb0cc2bf2.jpg?hash=UTt5Y9mKA1)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193605-c1dbe1de6643d6b6145087cbbb1ca5b7.jpg?hash=gZ2DLRgG0S)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193606-39f8856bc712f600596e6d6e18ee4929.jpg?hash=aAfek0neDG)
![[Hearth.com] Need Help: New Chimney & Hearth Install [Hearth.com] Need Help: New Chimney & Hearth Install](https://www.hearth.com/talk/data/attachments/193/193607-3a60bb7699051ac49b75f1ecf330a66e.jpg?hash=bcoepWZDgT)
