- Oct 3, 2007
- 1,539
The wife and I are currently working toward our dream of buying 10-15 acres and either mostly demolishing an old house and starting anew or building from scratch. I'm not looking to build some sort of compound, but we want to be as self sufficient as possible for a variety of reasons. First, this would be our second and last home, so we fully intend to reap the full benefits of return on investment in self sufficient power. Next, the places we are looking are in the most rural and isolated parts of New Jersey (stop laughing) where the power grid is old and even if it was new tree crews could never possibly keep up with the amount of trimming it would take to ensure that power lines never came down in the winter time. So between old transformers blowing up because of overheating/overloading in the summer, and downed lines because of ice and snow in the winter, it's nice to have a fall back. Most folks out there have gas powered gensets that they wheel out of the garage and plug stuff into, but I'd like something permanent and with more power output, but of course engine powered gensets are but one option, as I mentioned above, redundancy is a feature I want. I should also add that throughout construction we want to make use of good insulation and other methods of reducing the NEED for energy in the first place. We plan on building a milled log home, which, when properly sealed provides excellent insulating properties, but we also plan to incorporate other technologies/techniques as well (white roof, lots of attic insulation, quality windows, etc...)
The way I see it there are a bunch of options out there that can satisfy the two basic home energy needs: electricity and hot water:
Evacuated solar tubes - Hot water
Photovoltaic panels - Electricity
Wood gasification boiler - Hot water
Internal combustion engine powered generator - Electricity
I thought briefly about small scale hydroelectric as it would be possible to buy property where we're looking that may or may not have a stream with enough head to support it, but water use regulations and other challenges make it a little less attractive. Wind is something else I wouldn't want to get involved with either. Besides, with the above listed systems I would have two and two. My question is this-how do you tie all of this stuff together in such a way that it works seamlessly and can operate completely independent of the grid if needed? Let's start with hot water since that at least seems easier to me. Evacuated solar tubes are pretty simple devices that can generate very hot water even in cold weather, but of course are subject to the availability of sun. Does anyone here have evacuated solar tied in with a wood boiler system? If so how did you do it? Anyone have ideas on how TO do it? Either way I'm thinking that there would have to be some sort of computer controlled devices involved in order to regulate where hot water was going and how hot it was allowed to get. That's where I get totally lost...
Now for electricity. I realized a moment of frustration when I learned that most grid-tied photovoltaic systems do not work when the power goes out, presumably because systems that could adapt to power outages are much more expensive. The idea of being tied to the grid is attractive to me mainly because of the idea of selling power back to the company, plus my main fear would be if generator suffered a catastrophic failure that would result in me waiting for parts/etc...and in the meantime only having photovoltaics as a power source. So here is the question-if I were to install a photovoltaic system large enough to power the entire house plus a large permanent generator, how could they be installed in such a way that would allow everything to coexist? Would I need large banks of batteries? If so, what kind of battery life would I be looking at? Replacement every five years? Ten years? I realize that this is a lot to answer, but what I'm hoping will happen is that a bunch of folks interested in the same concepts get together and exchange some ideas and help each other better understand how this stuff can work.
