I am in northern VA and currently on all electric heat.
I want to go to something else for my supplemental heat. Use the heat pump down to about 40* then use either propane furnace or pellet furnace.
Obvious concern with propane is the volatile cost of propane. However, it is the simplest set up. Tied in to one thermostat, set and forget.
Pellet furnace - questions
- daily? weekly? maintenance.
- how are they tied in to the thermostat? would I manually have to shut off the heat pump one day in Nov and then turn on the pellet furnace? Or can it be set up like a propane dual fuel (set and forget)?
-How long can you be gone and let it run? vacations, etc.
I am faced with a $7K propane install vs $10K pellet furnace install. 120K BTU system.
