Hi folks,
This is the first time I have ever participated in an online forum so please bear with me if I screw something up.
I am building a new home and garage in Northern Ontario Canada on the northern side of Lake Huron.
I am planning to buy an EKO 40 or 60 and a backup oil boiler from Cozy Heat along with all the equipment necessary to heat the slab floors and DHW.
I have purchased a 1200 gallon fiberglass tank for my hot water storage system.
I plan to spray foam it (2 to 3 inches) and then bury it behind the garage (the boiler is in the garage as well).
I then plan to transfer excess heat from the boiler to the tank through a heat exchanger.
The tank will be a closed loop system.
When I need the heat from the tank I will reverse the flow and run the tank temperature down to a set point and then go to the boiler for heat.
Has anyone done something like this and would you help me with the layout and design of the control system?
thanks
Dean
thanks
Dean
