jkremzar said:I guess you haven’t read your stoves installation manual then.
This is a very vague manual........
(broken link removed to http://www.cornflame.net/images/pdf/5000_Install_Manual.pdf)
It is not as a stand alone. On the back there is an exhaust, inner ring and an outer ring. This site, you can see the back of the unit: (broken link removed to http://www.pinnaclecornstoves.com/Model) 5000.htm
The pipe goes about 8 - 10 feet up the chimney, from the inner exhaust.
OHHHHHH> The exhaust only goes 8-10 feet up the chimney............ It doesn't go all the way to the top and out through a metal plate that is sealed to the top of the chimney and terminated with a cap?
