Hello wood stove community. I’m excited to be a part of this forum and hopefully gain some knowledge here.
So I just acquired my first wood stove, a hearthstone harvest soapstone stove, and I am starting to gather my thoughts and ideas on how and what to build. My final idea is to build a bump out off the back of my family room to be able to recess the stove into the alcove to keep the rooms floor space intrusion to a minimum, as well as the aesthetics of it. The intended look will be a stone faced and stone interior “fireplace” with stove inside partially.
The side clearances are not really too big of a deal to accommodate but the rear clearances on this stove are pretty large (16” clearance from rear of heat shield!) I’m hoping to reduce that as much as possible, if possible at all. If I go the route of of building the interior rear face as a decorative “cover” to look the way I want it to, but to just be a panel with th 1” air gap method. How much would tha be able to reduce my rear clearance safely? I could technically just do the bump out/alcove as deep as I wanted but would prefer it to have as small of a void behind the stove as possible and also the smallest exterior protrusion possible.
Exact wall plan behind on the interior would be studs, cement board, cement board spacers for air gap method, cement board, and stone veneer grouted in. Additional questions with that are, in that setup would I be able use wood studs or should I do metal studs? The exterior wall will be getting stone faced as well and will need cement board and laff anyways, would I be ok to use plywood on the exterior outside of the studs? And what kind of insulation would be recommended for this application? Since this will be an exterior exposed setup, I will definitely need something.
Sorry for being long winded but I have a lot in my head and I’m excited to get going.
