Hello Everyone, total newbie here and in need of a little help from the experts. I have a "new to me" Harman P61A installed in my totally un-finished basement. I have installed a somewhat elaborate heat distribution system to get the bulk of the heat up to the main floor as I have no need to heat the basement. The system includes two 400cfm duct fans mounted way down-stream of the stove, an Aprilaire 600m humidifier w/additional 240cfm fan mounted post humidifier creating negative pressure inside the unit which "pulls" air into the unit and over the evaporative system, insulated 6" ducts and three strategically located floor vents on the main floor. This setup has been working very well for a few weeks while the temps have not dipped too low. But now that the colder weather has arrived I'm finding the stove is not able to keep my 2800sq two floor house warm enough on its own.
What I'm finding is the stove in either stove temp or room temp mode is not running hot enough at all, I have watched it for hours in both modes and I can see it throttle down. I have the best success running in stove temp mode with the probe sitting on the concrete floor but even still the stove throttles down. I want this thing to run more like a full on furnace. Even set with feed rate at 6, temp maxed out and distribution blower at max the fire is not always flaming high, sometimes it's just a very tiny flame (seems that's called a lazy flame), which tells me the electronics are holding back. And by the way, I have way more than 1" of ash on the lip, more like 2.5 - 3 inches with electronics set as described above, using New England High Quality Pellets so near no ash.
So my quest is to find a way to get this thing to crank, run at as high a temp as possible and get all 61,000 hourly BTU's out of this thing, yup run it like a furnace. How is that possible...?
Thanks everyone......
Rich
Rich
