Hi all!
I just purchased my first pellet stove and im looking for some tips on how to get the best results. I bought from a reputable dealer here in central michigan but figured i would bug you guys first. I installed the stove last night and it went well, however i wasnt impressed with the output of the stove by any means. Im going to chalk this all up to me not knowing what im doing. My fire is just barely visible over the firepot no matter what setting i turned the stove to. I was told to use the splitter once a day and drop the ash out but this morning there was no fire above the spitter for it to hold up. I am running MWP(?) pellets made here in michigan and recommended by the dealer and friends who have stoves. My stove is vented straight out through the wall and my home is about 1500sq/ft. Last year i spent over $400 a month to heat with propane and i couldnt take another winter of that. I have a few questions and any and all guidance would be greatly appreciated.
1. Am i out of my mind to think that this unit can heat my whole home. (realizing that the propane may need to come on when the temps hit sub zero)
2. How full should the fire pot be when i light it. (not an auto light model)
3. How long should i let each heat setting run for before stepping up a level?
4.what should my flame look like? Right now the top of the flames just creep over the top of the firepot.
5. Does anyone else have any real world experience with this stove and what are your thoughts and what size area are you heating with it.
The stove i purchased is used.
Thanks!
Thanks!
