Hi,
I've been googling a lot of my wood furnace questions lately and most of the info lately has come from these forums.. So here is my first post.
So I recently built a house 1200 sqft main floor and 1200 sqft basement... We are heating with a caddy wood/electric combo. Living in Northern Ontario.. Been running the furnace since early november now..
Anyways I have a slew of questions as I want to make sure I am on track.. We are heating 99.9% with wood.
My questions have to do with Jack pine, creosote, running hot/too hot/too cold and chimeny maintenance..
First off, we have a butt load of jack pine to go thru.. I've read this stuff can burn out a furnace if run too hot (and I think I have done that a few times) but will gum up the chimeny if run too cold.. Lately I've been just burning small to medium sized fires just to take the chill out.. The thermostat usually keeps the damper open until its just coals. The house usually stays warm enough for about 8 hrs after that, however there really isnt much left in the firebox after about 2.5 hrs.. Any advice on burning jack pine in this type of furnace??
Next quesion is about creosote.. I'm a little paranoid about this.. Just swept the chimeny for the first time this season (from the bottom). It was mostly fluffy type stuff but I can see there is a bit of the flaky stuff in there that I cant seem to get out with the brush.. Not sure if there is any glaze under there Any advice on chimeny logs/products and best methods?? Use just before or after a sweep??
I also just bought a flue thermometer... says to place 18" above the stove.. My pipe comes out the back does a couple quick elbows then straigt up.. I've just got it on the straight part where it goes up.. Does it really matter much on this type of furnace where the thermometer should be placed?? As well, when it gets going with the damper open the thermometer makes its way to the "good zone", but when the damper closes or just coals left, i'm back in the "creosote zone" Any advice on this??
I plan on having the whole system inspected this spring/summer for obvious safety reasons as well as to see how well I did my first winter..
Anyways, any advice would be greatly appreciated!
Thanks!
Thanks!
