We have an Avalon Prairie gas stove. It is shutting off after approximately 10 seconds of operation. The pilot stays lit while off.
One potential issue is that it has a very short flue. The stove is in the basement. The flue runs up approx 6' then turns 90 degrees, then runs approx 3' to the exterior of the house.
When we first got the house the stove worked fine. Now it doesn't
I presume there is some type of CO2 sensor in there that doesn't like the build up because the short stack can't heat up quickly enough.
However that doesn't necessarily explain why it used to work and doesn't now.
Do you know where the sensor is found? Can the sensitivity be reduced?
