Now, that's an ash pan!
Enigma869
282
Massachusetts
So, I just emptied the ash pan on my Harman P68 for the very first time, and all I can say is WOW! Who knew an ash pan could excite a guy so much? Coming from the Harman Accentra insert the past three Winters, WHAT A DIFFERENCE! The Accentra was a great stove, but the ash pan was beyond annoying. The thing needed to be emptied every 10 minutes! I'd be interested in hearing from other P68 owners on how frequently you empty this enormous ash pan? I'm so conditioned to emptying it every two days (in the Accentra, it's unmanageable after three days), that I'm just trying to get into a new rhythm with the P68. Could I actually burn a whole ton in one ash pan? Seems silly to ask but this pan is gigantic. I can see why they built a handle into the thing. This is going to make shutting the stove down in the dead of Winter a bit more manageable, just knowing that I don't need to do it, nearly as frequently.
Makes it nice for sure. I think I empty mine 3 times over the whole winter.
PC45 over 40 bags of ashy pellets easy.
For about 25.00 a good tinsmith could make another one and then just open the door and switch while running then shut the door. No need to shut the stove off.
no need to shut it off anyways.......yank the bin out, close the door, run out and dump it,put it back.......worked me for 14 years now
The last pellets I burned where a ton would fit in the ash pan, were DF's from out west. Actually, I don't think the pan was even close to full!..and they were only $174 a ton. But those days are loooong gone.
Anyway, the lowest ash pellets I've burned since are my current Orford softwoods. I'd be lucky if I could get 40 bags worth in the pan, and that's with a lot of Harman scraper tool compressings. NEWP and MC, I'll get about 15 bags. MWP, about 25.
Lousyweather is correct. If you don't have the time or ambition to shutdown and clean your stove, take your scraper tool, clean off the front couple inches of your burnpot, knock the stuff on the edges of the side ledges into the pan, and just empty it while the stove is running. Wear gloves! You'll need to clean up a little bit of ash but that'll take 2 seconds. Also, when reinstalling the pan, try not to snowplow ashes from the left side directly into the combustion fan. Actually, if it's that bad, your stove needs cleaning anyway.
