How far does OAK kit have to be from stove exhaust? From exhaust termination or wall opening? Installing pp130 stove.
And what’s the long answer Bub lolShort answer YES
Have you got two hours LOLAnd what’s the long answer Bub lol
Btw I got the pp130 instead of the outfitter I. More btu .. hope you’re happy lmaoI see no problem with that
I have a new PP-70 and nearly the exact installation in a corner using Duravent PelletVent Pro that allows for 1-inch clearance to combustibles. Because there’s a double stud that is only 12 inches from the corner, went up 2 ft from the T clean out, then added two 45 deg elbows, another 12-inch straight section to a 90 deg elbow and out. It’s a total rise of 4 ft. Aside from several maddening issues that had to get warranty replacements from Pelpro for (bad vacuum switch, control board failure), the stove won’t stay lit so can’t do a final inspection. We’re also at 8,000 ft. After troubleshooting with Pelpro and the manual (page 11?), consulted the table and with a t and three elbows, there is likely enough draft to create sufficient draft, especially at our altitude, and need to go a minimum of 11-12 ft vertical rise.. I have a similar eave challenge as you, so the only fix is to remove the 2-foot horizontal through the house and go vertical through the attic and roof. Meaning, I just ordered about $400 of additional venting supplies and I’ll have some extra work on my hands. Ouch. Should’ve consulted manual more closely.OK SO i was planning on doing my venting like this. Cleanout T inside. Go up 3 feet vertically ( can't do 5 cause soffit hangs too low) and then adjustable 90, and straight shot out wall to horizontal termination. Would that be fine? Despite what it looks like I am doing a
corner install so that's the reason for the adjustable 90 up top.
ouch ouch ouchI have a new PP-70 and nearly the exact installation in a corner using Duravent PelletVent Pro that allows for 1-inch clearance to combustibles. Because there’s a double stud that is only 12 inches from the corner, went up 2 ft from the T clean out, then added two 45 deg elbows, another 12-inch straight section to a 90 deg elbow and out. It’s a total rise of 4 ft. Aside from several maddening issues that had to get warranty replacements from Pelpro for (bad vacuum switch, control board failure), the stove won’t stay lit so can’t do a final inspection. We’re also at 8,000 ft. After troubleshooting with Pelpro and the manual (page 11?), consulted the table and with a t and three elbows, there is likely enough draft to create sufficient draft, especially at our altitude, and need to go a minimum of 11-12 ft vertical rise.. I have a similar eave challenge as you, so the only fix is to remove the 2-foot horizontal through the house and go vertical through the attic and roof. Meaning, I just ordered about $400 of additional venting supplies and I’ll have some extra work on my hands. Ouch. Should’ve consulted manual more closely.View attachment 327041
