Older VC Defiant stove....but never installed/fired - worth the gamble?
cptmoney
46
Western Colorado
So....we're in the market for a wood stove. Never owned one, so while we're in the middle of a living room remodel, we figure we'd like to add that to the mix. The heat would be nice, and hopefully more affordable. Wood is plentiful in our area, so the stage is set....our home isn't monstrous, but at 2400ish sq ft, a larger stove would be what we'd be aiming for.
We've been looking around for a good deal, and think we may have found it, but I'd sure appreciate your input on the matter -
I've run across a brand new, never been installed nor fired Vermont Castings Defiant, Model 1910. It's a catalytic model, and comes with 8' of DuraVent 6" single wall and 9' of double wall chimney pipe, as well as the ceiling box and chimney cap. All brand new never been installed as well. Stove is the baked enamel finish (is that what it's called?), and looks to be just as described. Supposedly has a loose leg - that's the one thing not perfect with it, and has no additional pieces (i.e., front screen, side wings, etc.).
According to the seller and his conversation with the local dealer, the model number places this at about 2002 year model.
The entire lot of it is priced below $600.
I've read many reviews on this stove (here and elsewhere), and they range from amazing to not so amazing. It appears that the VC company in general has been through all sorts of transition in recent years, and may still be shaking things out. This stove is/was an anchor to their establishment, but this is a newer model with the cat. and all.....so I'm on the fence.
My question is this: knowing that we're first-time burners, with no real experience - BUT keeping in mind that we're on a tight budget (and who isn't, these days) - is this worth taking the plunge over? According to some reviews, this stove is a homerun, with long burn times and great steady heat....but others say it's a fickle stove that can be expensive to repair. At under $600, is it worth the gamble?
I'm inclined to buy it before it gets away, and even if the stove isn't the right fit for us, I think I could sell the stove alone for the asking price - and I'd have my chimney pipe for basically nothing!
What are your thoughts? I'm very anxious to know what you think....
That sounds like a decent deal. The VC cat units are not bad heaters, it was their downdraft stoves of that vintage that had the worst issues. It may need a cat in 5 yrs and a rebuild in 10 yrs, but the stove won't owe you anything at that price. The enamel version is beautiful and the loose leg probably just needs a nut tightened.
The main thing you will need to make this stove happy will be enough chimney for your altitude and dry wood to burn. You may need to add a bit more chimney. There is an altitude chart in the manual. Get the most seasoned, split wood you can, right away. High altitude spruce can be pretty good firewood.
I would do it as you seem to be getting your money's worth in chimney parts already. The stove is almost a "throw-in". Burn it a few years and when it starts failing shop for another one. Hopefully, your money situation will look better then.
If you do decide to go with this stove please follow the manual's guidance for installation carefully. This is a strong heater that needs to have its clearance and hearth requirements honored. Feel free to ask questions about the installation. We want you to be safe first, then warm.
I think we're going to go for it, if for nothing else....because of the chimney parts. I think the stove will work out very nicely, as long as we can figure out how to properly run it.
begreen - it's your comment on the downdraft stoves that I need! Thank you! I don't know anything about wood stoves, much less about wood stoves that were manufactured over a decade ago. This is where your opinions will save me countless headaches.
I know the seller has all the original documentation, so that's a plus. We should have good instructions regarding clearances on installation.
We're scheduled to see it this afternoon, I believe.....so we'll know more once we're in front of the actual unit. Does a wobbly leg make anyone anxious? Anything to be worried about? He said it's holding itself up just fine, it was just something he noticed. I'm hoping that it's nothing more than the loose nut that begreen mentioned.
Anything else I should be paying attention for once we're right in front of it? If there's never been a fire in it, I'm guessing that things will be pretty straightforward.
Again - I really appreciate your input. VERY much. I have to act pretty quickly if we're to acquire it. He's giving us first "rights of refusal" so to speak....but then he's going global! Haha. If you think it's worth it, we'll jump in and get the ball rolling. I don't see how we can go wrong in the big picture.
If everything is indeed brand new (never used) then,
no brainer....go for it.
If you want to check already regarding clearances etc here is the manual:(broken link removed to http://www.fergusonfireplace.com/1910.pdf)
I'm seeing the term "heat shield" and "wall shield" and "double-walled connector"......boy, the learning curve on all of this is STEEP. Lots of reading to do.
I'm thinking we'd prefer the corner install, but to really get it tucked in, we'll need all kinds of non-combustible wall shield. Where do you find a heat shield? Does that have to come directly from VC? Or are there generic shields available?
I have a corner install. I was able to bring mine in 12" measured at corners. But I had to build a shield with 1" gap behind it. I used dura rock on metal 2x4s and on the face I put nice cultured stone. Turned out nice.
That wall will get to about 190*f uneasily.
If you are new to burning there is a distinct possibility that you don't have dry wood. A cat stove is more tolerant to wet wood then other more modern stoves. At that price I would buy it and learn with it for a few years then once you got ahead on wood and can plan on really dry wood you can sell for a bit less than you paid for it and then go with a higher tech stove.
Not true, if its a ceramic cat it could get heat shock and crack, the inside fins (guts) can get plugged up from creosote
You can make your own. Essentially a non-combustible material spaced an inch from the wall and open at the bottom and top to allow airflow. Here is a description:
https://www.hearth.com/econtent/index.php/articles/stove_wall_clear
OK.....so the plot thickens!
I went over to check out the stove, and found a few things that bring up more questions....
First off, the enamel finish is chipped/repainted in many places. Definitely not a deal breaker for us - but I have a question: how do I know the touched up areas were done with a high temp enamel paint? Are those touched up spots going to burn off to black, leaving be with a green/black Dalmatian stove? The seller knows nothing about it, so there's no help there. Here's what I'm talking about:
[Hearth.com] Older VC Defiant stove....but never installed/fired - worth the gamble?
Secondly, the right front leg (as you're looking at the stove face) has been broken off completely at some point, and somebody has tried to weld it back together, but it's not holding. It's the leg in the photo above. The leg is still quite wobbly, and it's discolored from the last attempt to repair it. Looks like I'd need to purchase the entire right side of the stove at an approximate cost of $250, give or take. This IS a deal breaker for me...unless I can get it repaired. Just the safety factor makes me nervous about this. The leg shows some heavy wear compared to the rest of the stove, for what's it worth.
Third - the stove genuinely looks brand new. Fire bricks are all stone white, The metal appears brand new with only surface rust. Same with the stove pipe; it all looks brand new. Here's what I saw:
What do you think now? Things coming into focus a little better? Even though it's a great price....she's got some baggage. I'm chasing a new side panel while in a holding pattern. That's got to be right for my own peace of mind. So far, $246 is about the best price I've seen.
At some point, it appears to have been sold through discountstove.com, as I noticed some notes in the owner's manual that seller produced. Not sure if that matters, just putting that out there.
P.S. - sorry for some wonky pictures; I was using my cell phone!
This was a $2,000 plus stove that you can get for considerably less. The going rate for used VC stoves on Uncle Henry's is $400 to $600for 20 plus year old stoves. It obviously was a shop worn unit or possible a return that may have sat in the back room a dealer for awhile. So it comes down to your tolerance for flaws versus the savings. Some folks are willing to pay the difference, I wouldn't. I expect you can buy a new leg but getting it to match color would be difficult. Not sure if all the legs are the same but pick the corner that is least visible and swap the legs around.
Is it possible to get a picture of the underside of the unit where the broken leg is bolted? The spray paint that they have used to cover up the chipped enamel will most likely change color slightly when the stove is used. The paint will fade/discolor over time and will have to be touched up. If it were me I wouldn't be willing to offer the $600 if the entire side needs to be replaced. Perhaps $500, if that.
It all depends on how the leg is broken off.
If the stove body/side (where the leg attaches) is damaged then yes....the whole bottom/side panel needs to be replaced. A whole stove disassembly.
If only the leg is damaged then a 25.00 ebay purchase. My encore legs are not corner specific, I imagine the defiant is the same. If there is only one part number for the legs, then you are good to go!
I looked for an hour last night, poking around the internet looking for just a leg - buy couldn't find it. It appears as though it's sold as one big side piece only. I'm new to all of this, and could easily be mistaken...but that's all I could find. Cheapest was the $246ish version.
The cosmetic flaws don't bother me. The price makes up for that. It's the image of a full stove at roaring temps, rolling onto its face, spewing burning coals that has me backpedaling at the moment. I'm not giving up yet...just need to get that leg dealt with.
If you have the manual, look up the part number.
I am sure the legs sell separately
Also, is the catalytic converter included ?
I have the digital manual that Grisu posted just a few posts above this one. Exploded parts diagrams don't show the legs as separate pieces, only a component of the sides.
If I'm understanding the same said exploded parts diagram, then yes, the catalytic converter is included.
I did forget to ask about one thing. Check out this white stuff around the upper stove chimney outlet (not sure what the technical term for this piece is!):
That anything to be concerned about?
Here's a quick pic of the inner side of the converter -
Looks as though there were some rodents bedded up inside at some point, but I bet a few minutes at 600 would take care of that in a hurry!
I would hate to see the shipping bills this stove has accumulated. It looks like it may have traveled with a gnome at some point.
Someone qualified could likely weld the leg securely in place but being cast parts, it's not as simple as the previous person to give it a go thought.
Now you just have to decide what condition the stove must be in to burn in your home, how much money it will take to get it there and are you willing to do it.
Me personaly, I would get it. It's a few months til you need it so you have some time to get it right and if at some point you change your mind about the stove it should be an easy sale closer to winter.
I stand corrected. After looking at the diagram, the legs are part of the side body.
So, unless you have a quality cast welder look at the leg, replacing the whole side would be very labor intensive.
Looks like it might have fallen in shipping and landed on the right front side. Value is going to be up to you. You could fab up a leg out of angle iron if need be or slip a concrete block under that corner. It wouldn't be pretty, but it would save some dough. Personally I'd only take the stove if cheap and figuring I could get 5 yrs of good burning out of it without additional cost.
So...I'm in a holding pattern for now.
I spoke with the seller, and he didn't love the idea of coming down on price even further, especially when the dealer told him this stove normally sells for thousands of dollars. I told him that even so, with the leg issue, I'd need to have that addressed for my own peace of mind. He's going to think about it.
I do have a close buddy who's a heck of a welder, and I've left him a message but have yet to hear back from him. I'm sure he'd be willing to give it a go, but I've never had with much luck with welded cast. It's a band-aid at best, in my experience.
Thanks for all your input. I genuinely appreciate it. It has been invaluable for us. Muchas Gracias!
