So season is firing back up. Who leaves the stove on while at work?
I normally leave my stove on. Mode depends on outside temps.
Set thermostat for furnace at a minimum temp, let’s say 65 degrees, so that in the event the pellets run out, or if running in Stove temp mode and the weather turns more frigid, the furnace will cover the added load. Also it’s not a bad idea to allow the furnace to push hot water through the pipes to prevent freezing/cracking in the far off nooks and crannies.Do you turn your furnace off when you leave? Your water heater? Same thing.
I'm single and without children, so the decision is made on my desire to either have a warm house or save pellets. If I had kids, the decision would be made around their lives. But the climate here in Hillsboro Oregon is quite mild for the most part. We may get a short few days of 15 degrees F in dead winter, but for the most part, high 30s and 40s at night and high 40s and some 50s in the day time. So if the house is over 70F when I leave, it gets turned off. If it has'nt quite made it to 70 because I started the stove late the prior eve, it may get filled and left run.
Pellets are my sole source of heat and I run the stoves on manual like the old days of using a wood stove. I'm happy.
Same here.On, however that depends on outside temperatures. If it is cold and windy, definitely on!
Bill
