outside air kit question
steevo
90
central ct
I run an enviro windsor pellet stove during the winter. it stands in front of my fireplace on a tile base. Thinking of possibly installing a oak, but really have no way to run it outside. The stove is backed up ti the fireplace as I use my chimney liner for exhaust. I dont want to drill through the brick and there is no wall near to go through easily.
Can i drop a 2" flex pipe through the fireplace cleanout into my cellar and hook it up tothe outside down there? not sre if being to long would effect it or not.
Reactions: bags
Yes, you can do it that way.
Reactions: bags
The manual for the stove might have some verbiage around length and diameter of the pipes (both exhaust and intake).. that might be a good way to validate you don't need to increase the speed of the exhaust fan.. maybe? .
In my case, i am already at the basement and i do use the fireplace cleanout for "fresh" air via a flex pipe. It works.
Reactions: bags
Short and simple works!
