Thinking of storing 2-3 tons of pellets outside in shed . Will rodents bother with bagged pellets? Anyone ever have a problem storing pellets outside?
As soon as I gain another shed or free up space in my existing one that's what I'm doing too. Build it tight, I doubt mice will bother it much but squirrels and rats might. Big maybe.Thinking of storing 2-3 tons of pellets outside in shed . Will rodents bother with bagged pellets? Anyone ever have a problem storing pellets outside?
But the little buggers will make nest of plastic and anything else around and the pallet provides a nice dry home. Found a nest in a ton in the shed that had been double bagged and wrapped for outdoor storage and low and behold the little a$%&$ made a nest. Not damage to the bags but did stink.
There's no food value in wire insulation, but they will chew the crap out of that too......There is no foo value in the pellets so I don't think they care about them.
Ron
Most wood pellet dealers leave their pallets outdoors. As long as the factory plastic wrap is still intact it shouldn't be a problem.
They chew electrical wire that has current flowing in it because the 60 cycle hum bothers them and there trying to stop it. I have never seen any wire damage on wire that isn't connected to anything.
Ron
You can test those pallet liners yourself. I've done it when comparing liner vendors. Some that claim to have a moisture barrier, don't. Just take a piece and fold up the sides and staple the corners to form a bowl and place it on a paper towel. Then pour water in it. With a true moisture barrier liner, the water will evaporate before any of it leaks through.
Okay. But you mentioned the 60 cycle hum. I was just pointing outThe only time car wiring doesHz in a car...t have noise on the wire is when it's not running. Then it's pure dc. My point is they can hear the electrical noise that is transmitted on the wire. Two of my sons are master certified mechanics so I do here the stories.
Ron
there was no 60hz in a car...
Dan
Depending on alternator poles!... YMMVExcept from the alternator right around 3600 rpm.
I was going to write the same.... My daughters Corrola parked in Astoria NY suffered a chewed harness - $600 worth of damage. Dealer said soy product in the cable. Tick me off!OK heres your car fact,not story.Many japanese cars,and cars that have wire harnesses built overseas,are very prone to rodent damage.They found out it was because the insulation(and a lot of plastics) were made from soy.Newer vehicles (about 2008 and up)now use a different blend so problem not as bad.Rodents also attracted to the interiors(through heater box) because of this problem.Wire screen on heater intake and aluminum tape on harnesses are the fix,before anyone asks.ASE Master for many years.
