Over Fired Stove
Don H
290
Maryland
I've seen it mentioned here when people look for a used stove they like to see it unpainted so they can tell if it's been over fired.
What does an over fired stove look like?
What damage is done?
What would you look for that would prevent you from buying a stove?
The words All-Nighter, Frontier, Huntsman, Schrader or Timberline on them. ;lol
But seriously, some buyers require a Fisher to be a later UL listed model for legal use in their area. That prevents most from buying, or being in a state where only EPA certified stoves can be used.
This is hot, but no damage was done. Only paint discoloration in this case;
[Hearth.com] Over Fired Stove [Hearth.com] Over Fired Stove
Side panels may warp. A straight edge on the side will show a bulge. Cracks will emanate from around vent outlet but can be stop drilled and welded easily.
Check the moving parts. Excessive wear in hinges can allow doors to sag and seal poorly, extremely loose draft cap threads can soon cost you an expensive draft cap. They are still very fixable.
I stay away from stoves missing doors or having cracked doors. Any Fisher that has been stove blacked is a lot of work and I'd pass unless exceptionally special. Coal Bears missing grates or inner liners may never be original again since those parts are next to impossible to find in good shape. Most anything else is fixable.
