Overburn problem
AltaVistaStove
9
rapid city
I can't turn down the airflow on my 2008 Alderlea T5 enough. Door gasket seems good. Just put in new door glass and gasket since glass had cracked and glass gasket was leaking air. Thought that would solve my air flow problem. It made it better but still can't slow down the flow as much as when new. I've inspected things and don't see anything warped from overheating and the damper seems to be working right but I can't restrict the incoming air as much as I'd like to control the fire. When new I could shut damper far enough to slow the fire down to a simmer but now even shutting the damper down all the way I get more of a burn than I'd like. Makes me careful not to add much fuel at a time as afraid it might burn to fast and hot. Any ideas appreciated on how to deal with this.
Welcome. Do the dollar bill test on the door at multiple points and make sure the door glass gasket is sealing all the way around. Also, are the insulation blocks on either side of the baffle in good condition and touching up against the baffle? Has the baffle secondary tube gasket been replaced after cleaning?
Another thing that can change is the species of wood, its dryness and thickness. Some types of wood burn hotter and faster than otheres. Thicker splits will burn slower.
Is the stove being loaed N/S and tightly packed?
Thanks for the reply! I just watched some UTube videos. Will be easy to do the dollar bill test. Will also try to take out the baffle to inspect. What would tell you that a new baffle is needed? Anyway this all gives me hope I can fix this stove and continue to use it!
It takes a lot of abuse, typically overfiring a lot, to wear out a PE baffle. A baffle will need to be replaced when
it no longer can direct secondary air properly. This usually shows up as a bad sag and rupture on the bottom side or front edge. Our T6 baffle is the same age as your stove and it is still in very good condition.
Was the fire controllable before the glass cracked and was replaced? Do you have any sooty areas around the glass?
Where are you located?
It was more controllable so I think part of problem was the glass and old glass gasket was leaking air into the burn chamber. New glass and gasket helped some but did not solve the problem. I'm going to replace the door gasket also though I don't think that is the problem. Also plan to take the baffle out and look things over. Not any noticeable sooty areas around the glass. Glass itself stays pretty clean.
Want to get this figured out. When I first got it it seemed to provide more heat and was more controllable flame and just not sure what happened. Baffle doesn't look too bad as far as I can see but will take it out and look more closely at it. I'm located in Rapid City, SD in the foothills of the Black Hills. I have started really looking at YouTube videos about this stove. Even after using it for 17 years I'm still learning things about it.
It’s possible your wood is dryer now than it used to be. I start turning my stove down as soon as the fire starts hitting the baffle regularly. Turn it down in small increments. The fire will die back and then rebuild as it adjusts.
For a proper door seal, be sure that the door gasket is the original PE OEM part. Substitutes tend to not seal as well and are leaky.
Thanks! I did just order and receive an OEM door gasket so I plan to install it before burning season. The one presently on the door is not OEM though I can't detect any major leaks. Decided to switch to original gasket just to make sure.
Reactions: Itslay90
Ordered online from Stove and Grill Parts For Less. They also have a non-OEM baffle for my stove for about $250 vs about double for the OEM. Need to take my baffle out and inspect and hopefully I don't need a replacement. It looks pretty decent just from what I can see.
Reactions: Itslay90
I took the baffle out of my Pacific Energy Alderlea T-5 today. It was in pretty good shape, one hairline crack on the front. I blew compressed air through it to remove any soot/dust buildup inside. I did notice that there is NOT a baffle gasket installed. Not sure why. Can't remember for sure but think I took baffle out once about 10 years ago just to clean things up as far as soot and maybe baffle gasket was lost at that time. Seems like I saw on a youtube video that that gasket is rather important so I'll order a replacement. Maybe that has been part of my problem.
I suspect that is the issue. About 5 yrs ago, I tried two different non-OEM gaskets. Those gaskets easily passed the dollar bill test, but they still leaked air. The OEM gasket is double-layered, more like a gasket inside of a gasket. It seals better.
Went down to my local Pacific Energy dealer where I bought my stove to purchase a new baffle gasket and found out they had done out of business. Have been having difficulties finding this item online. Can anyone point me in the right direction or suggest an alternative to using the OEM baffle gasket?
While I am a strong proponent for only using the OEM door gasket, the rear baffle gasket is a much less sensitive part. You could create your own out of 1/4" door gasket, or get a sheet of 1/8" or 1/4" ceramic gasket material and cut your own. I've been using a rope gasket for about 5 yrs now and am going to try cutting my own from a sheet of ceramic gasket this summer. To do this I'll probably make a cardboard template first. I'll be using something like this material.
If you want to try making a rope gasket, Hogwildz documented the process years ago.
Reactions: begreen
Typically the baffle gasket should be replaced any time you drop the baffle for cleaning. I don't think I did mine last year because it was still fairly intact. If you're careful with how you remove the baffle then the gasket may stay intact and be fine to use for another season but I'd imagine after 10 years that thing was long gone even without removing the baffle. I used to just buy about 5 at a time from the dealer so I had them on hand, but I did happen to see some on Amazon yesterday which I believe were OEM.
