Good Evening All...
It's finally starting to get cold here in New England, so I'm burning a bit more often than I was. I'm thinking that with temperatures in the mid-fifties tomorrow, it may be a good opportunity to clean my Harman P68 for the first time. I'm coming from an Accentra insert, which seemed to have much more to cleaning it. I used to take the steel plates off and scrape down the heat exchanger with the Harman tool that came with the stove, and then run the brush through the exhaust holes on either side.
According to my dealer, there isn't much to do with the P68. In fact, he told me that there was no need to remove the fire bricks to clean it. He said he does that once, at the end of the season cleaning. He said that I simply need to loosen the thumb screws on the underside of the burn pot and vacuum inside of there well. Is that it? That seems WAY too easy. I assume that I should try to vacuum the fan area in back of the ash pan? Where is the heat exchanger on the P68? I'm used to seeing the grooved exchanger on the Accentra that the tool was perfect for. Any and all advice offered is GREATLY appreciated. I just want to ensure that I don't miss anything that I need to be giving attention to.
John
John
How to clean it!
