Yesterday at 6:34 PM
Hello,
I just got this pellet stove from a friend. Worked fine for a few days, now an outlet in the barn is popping afetr a few minutes of starting up "SU". If I press the button back in, the stove turns back on and starts up again. A few minutes later it pops the plug, (nothing plugged into this outlet) and not the barn breaker box? If I put it into shut down or off mode, it does that until its cool then shuts off. I found that the tube in the back was brittle so I cut a piece off and replaced it back. Then I cleaned out the hole with a toothpick in the front by the ignitor. This has happened many times, should I check for a blown fuse?
Hello,
