Looking for recommendations on a pole saw. I'm looking for a gas unit, preferably something that will last forever with the proper maintenance. I do have a local Stihl and Husqvarna dealer, nothing but good experiences with Husqvarna.
The beauty with Stihl is that no matter how old and crappy it is, someone will always pay a crazy amount of $'s for it......Looking for recommendations on a pole saw. I'm looking for a gas unit, preferably something that will last forever with the proper maintenance. I do have a local Stihl and Husqvarna dealer, nothing but good experiences with Husqvarna.
My local dealer carries Husqvarna and Stihl under one roof. He used to prefer Husqvarna but likes Stihl now. I have no brand allegiance and just want what will work the best and fatigue me the least.The beauty with Stihl is that no matter how old and crappy it is, someone will always pay a crazy amount of $'s for it......
I own both and am happy with both. I can tell you that whenever I upgrade, Stihl is much easier to sell as a used item.My local dealer carries Husqvarna and Stihl under one roof. He used to prefer Husqvarna but likes Stihl now. I have no brand allegiance and just want what will work the best and fatigue me the least.
We have the Stihl Kombi. Works great, powers thru stuff better than I was expecting.
My friend has a Stihl Kombi as well and really likes it. Honda also makes a Kombi-esqu system called the Vet I've heard good things about. The Honda is 4-stroke vs. the Stihl 2-stroke
Distinction:
Stihl's pro line KombiMotors are not 2-stroke engines. The "4-Mix" engine essentially is a 4-stroke engine that lubricates from 2-cycle fuel mix instead of the oil splash or pressurized oil system found in other 4-stroke engines.
Correct, but the way I see it one takes 50:1 mix and the other straight gas and you change the oil like a vehicle. I'm not sure how the Stihl 4-mix motors handle valve jobs but i guess that's another consideration.
Just like any other small engine valve job. Use a feeler gauge to adjust the clearance on the intake and exhaust valves (lots of videos on YouTube showing this). Stihl sells a valve clearance setting kit with the feeler gauge and replacement valve cover gasket if one is needed.
In addition to their nice torque, I actually like Stihl's 4-mix engines because there's no oil to change and the valve system remains clean and reliable if the recommended 2-cycle oil is used.
We have a Stihl that is 11 years old and it has never been in the shop, I'll get the model number before noon.Looking for recommendations on a pole saw. I'm looking for a gas unit, preferably something that will last forever with the proper maintenance. I do have a local Stihl and Husqvarna dealer, nothing but good experiences with Husqvarna.
Ditto. I am normally NOT a fan of combination tools like this, but for tools that get used as infrequently as my pole saw or bed edger, they’re perfectly suited. No need having an engine laying around that only gets run once per year, as would be the case with my bed edger.
Stihl Kombi is done right, IMO. I just bought the biggest engine they made (KM 131 R), and all the attachments I needed to go with it. So what if my string trimmer is 1.9 hp? Doesn’t everyone need that? [emoji12]
BTW, with only one exception (the smallest model), every one of the Kombi motors weighs exactly 4.4 kg. So, there is zero reason to even consider buying any but the largest one. I don’t know why they even make the other models.
If you anticipate infrequent use of a pole saw, to trim lighter low limbs (up to ~25 ft) from trees, why not get a manual pole saw with extension rods, like this one from Jameson, with three 6-foot poles and 16" blade: https://www.amazon.com/dp/B0077S1ASO/?tag=hearthamazon-20
A 21-minute Jameson video on their tools (poles and attachments) is here:
That does seem like a nice tool, but I would want a gas unit for more regular use. This would be a great saw to have for really high up stuff.I have one of those. Also Jameson, very old with wooden poles, but still uses the same end fittings. I have about ten of those 6 foot extensions, but have found it becomes pretty unwieldy beyond 42 feet. I think I used it once at 48 feet, and almost broke a socket “getting it up”.
I have the saw blade, hook, and lopper attachments, they may make others.
I just checked, it is the HT 101 from Stihl we have, we bought it to limb up a bunch of old dead pine branches for walking trails after our house was built almost 16 years ago. It has never been in for any type of repairs.Looking for recommendations on a pole saw. I'm looking for a gas unit, preferably something that will last forever with the proper maintenance. I do have a local Stihl and Husqvarna dealer, nothing but good experiences with Husqvarna.
Agreed. I only use it for stuff that my powered one can’t reach. Of course, a LOT of what I’m cutting seems to be stuff my powered one can’t reach, so I do use it quite a bit.
