Eric Johnson said:"Relative" moron in technical matters. My talents lie elsewhere.
I'm in awe of you guys.
Eric Johnson said:Not to hijack the hijack, but I'd like a layman's description of what you've done with that Grundfos pump, nofossil.
Would it be fair to say that you've replaced a three-speed switch with circuitry that allows an infinite number of speed settings, made by a computer, within the speed range of that pump?
And if so, how is the speed regulated? Would it be analogous to a computer-controlled dimmer switch?
What happens to your boiler if your computer network goes down? Does it default to the boiler's controller?
nofossil said:Eric Johnson said:Not to hijack the hijack, but I'd like a layman's description of what you've done with that Grundfos pump, nofossil.
Ray has it exactly right - my relays replace the manual switch. It's still a three speed pump, but now it can be controlled by the computer in response to inlet and outlet temps.
It does in fact default to the boiler's controller if my controller goes down. In that case, it runs at high speed when the EKO applies power. That's what I mean by 'failsafe'. I've been pretty careful to design everything that way. If my computer went down, everything except storage would continue to work fine - just like it came from the factory, so to speak.
Part of my makeup is that I'm really cheap. This pump with mods is cheaper than the industrial SCR speed control that Jersey Bill was kind enough to reference. I'll be buying one of those for my fan, where I need a lot more control than just three speeds, but I'm more happy with this cheap pump solution. I get a lot of satisfaction in figuring out inexpensive but technically sound solutions to this kind of problem.
To be even more specific, my controller will work fine without the network - all I'll lose is datalogging. Coming from an aerospace background, I'm a little obsessive about thinking of failures and how to minimize the effects.
steam man said:I came across this site while researching variable drive stuff for my own project. Looks interesting but I have never seen any of it used. Probably more of a rich man's thing. I'm cheap too-or so they say.
http://www.controlres.com/ac.htm
termite said:Could something like this be utilized to control a pump? My idea was to replace the pot with a thermistor/resistor network to control pump speed. I've tried to attach photos of the pertinent pages of the manual. If they aren't readable I also attached the link. These are $5 on ebay, by the way. I bought some for R&D;. If anyone has any ideas let me know and I'll butcher some of these up.
http://www.kbelectronics.com/catalog_fan_dist_panel.htm
ABGWD4U said:Solid state switching is ideally suited towards applications in the HVAC world.
I am not certain the model your espousing for your system. But, it is going to depend on your circ.
I am also hazy on how you propose your going to use this in conjunction with thermisors. But, you definately are hitting on a technology that runs parallel or over what we deem as the "poor mans variable speed pump"
nofossil said:termite said:Could something like this be utilized to control a pump? My idea was to replace the pot with a thermistor/resistor network to control pump speed. I've tried to attach photos of the pertinent pages of the manual. If they aren't readable I also attached the link. These are $5 on ebay, by the way. I bought some for R&D;. If anyone has any ideas let me know and I'll butcher some of these up.
I think these would work for manual speed control. The Taco is a PSC (permanent split capacitor) motor, ifI remember correctly.
The problem with these is that I don't have enough circuit design experience to figure out how to adapt them to computer based control. If anyone wants to chime in, I'll try it.
nofossil said:ABGWD4U said:Solid state switching is ideally suited towards applications in the HVAC world.
I suspect that termite was thinking about replacing the pot in the KB controller with a thermistor and resistor so that the pump speed would vary with temperature. That probably would work within a range of temperatures. Thermistors are wildly non-linear and you have to limit current to prevent self heating, but it's an interesting idea.
What I want is the same circuit, but with an electrically isolated 0-5V analog input so I can control it directly with my computer.
The Crydom controller mentioned earlier is very close to what I want. It handles a lot more current than I need, the input voltages don't quite match my outputs, and it costs more than the pump. I'll still probably get one unless I can figure a way to use this cute little KB unit.
If anyone can suggest a way to modify the KB to fit my needs, I'll test it and post a writeup on the mods.
raybonz said:I think these would work for manual speed control. The Taco is a PSC (permanent split capacitor) ....
termite said:raybonz said:I think these would work for manual speed control. The Taco is a PSC (permanent split capacitor) ....
They work manually. I've played around with that. The current draw goes up a little when you slow the pump way down. I'm not sure if the speed control unit is soaking that up (the triac heat sink does get warm) or if the pump motor does.
Nofossil: If you want one to play with I'll mail you one.
raybonz said:You are correct that the Taco 007 is a PSC motor so no speed control can be used on that model pump.. Check out this bad boy they make: http://www.taco-hvac.com/en/product...Circulator/products.html?current_category=194
Ray
Sorry I messed up you CAN use speed control with this motor.. Think I'm going brain dead..
Ray
nofossil said:raybonz said:You are correct that the Taco 007 is a PSC motor so no speed control can be used on that model pump.. Check out this bad boy they make: http://www.taco-hvac.com/en/product...Circulator/products.html?current_category=194
Ray
Ray
I looked at Taco's variable speed pump. It was around $600 three years ago. That's more than all three circulators in my system PLUS the 7260 controller, A/D boards, additional digital I/O board, relays, and wiring.
raybonz said:5 dollars was a real bargain on those speed controls! Were they brand new?
Ray
termite said:raybonz said:5 dollars was a real bargain on those speed controls! Were they brand new?
Ray
Yep, brand new. Search for "Solid State AC speed Control for Blower motors" in Ebay. I paid $4.95@ for mine. He has jacked the price up to $5.95. He had a bunch of them when I got mine. He has three up right now. They are the KBMC-13's.
Termite,
Have you considered R1 as your point for speed control? Once you know the value you could replace R1 with an external resistance if it is standard such as 1k, 5k, 10k, etc. . Being 2 wire it would be simpler to do.. Just a thought..
Ray
No I haven't, but that's a good idea. That would be a lot simpler mod. The functionality of the speed pot would be preserved as well to help fine tune for the application.raybonz said:Termite,
Looking at the schematic I am wondering what voltage your dealing with. Looks like it will be AC not DC so you gotta be sure that your control device is rated to handle the voltage.. You sure have me thinking!termite said:No I haven't, but that's a good idea. That would be a lot simpler mod. The functionality of the speed pot would be preserved as well to help fine tune for the application.raybonz said:Termite,
Sled_mack mentioned not letting the speed drop below 60%. The R2 pot would be the place to make that adjustment.
raybonz said:As long as you can desolder the speed pot you should be able to use external speed control once you determine what voltage they're using at the pot you may be able to use 0-5v or 0-10v or even 0-2.5vdc reference all of those being common. It's too bad that KB doesn't make one of those with external reference as an option.. I have used KB DC drives and they work pretty well and are very compact.. Will be interesting seeing who figures it 1st.. My money is on Nofossil..
Ray
nofossil said:I'm hoping an electrical engineer will look at this and post a simple solution - "You just need to desolder the pot and stick in an AD-97532 optically isolated fribblespatzer."
