have a Quadrafire 1200i Pellet stove insert that up until this year has been flawless. The unit is 7 years old and I had it cleaned last week as I do every year. After it was cleaned I noticed the unit would not turn on when set to higher than room temp 70-75 degrees). I was told by chimney sweep that it was the control box after he troubleshot it for about 30 mins. I replaced the control box and the problem remained, after investigating myself I found out the thermocouple was bad (wire snapped under the cover). I replaced the cover and thermocouple and the unit fired right up, the only problem was it was not feeding enough pellets to keep the fire going. After further research I learned the setting on control box needs to be set to #1, did this and it works just fine. Now my thermostat reads 70 degrees no matter how long the fire burns (burned all last night without shutting off), I replaced the thermostat today with one similar from lowes (one red wire and one white wire) and it comes on fine but will not shut off unless done so manually. What could the problem be? Please advise, I'm going crazy trying to figure this out!!
