Power wattage of a Englander 25-pdvc for battery back-up calculation.
Fraulein
3
quebec
Hello friends, I am new here. I am in the process of getting a Englander 25 pdvc wood pellet for my house. We have frequent power outage during the winter. they can last from 1 to 5 days. I need to know the power usage of this stove in order to put up a battery back up system. I already have a UPS, I just need to beef up the batteries.
I already saw video about the power usage while the fire is well established. A Harman is about 300 watts to keep it running. A Castle serenity is about 68 watts. These measure were taken with a Kill a watt device. I could not find the numbers for an Englander 25 pdvc. I wrote to the customer service at Englander.com. a couple of days later, I only got an "I Dunno" answer with only generic information.
Is somebody already plugged a Kill a watt device in a Englander 25 pdvc while it is running? This will help me to put together a battery backup that cold keep my stove running for a couple of days.
Thank you
gfreek
1,694
WNYS
Welcome to the forum...Some one should be here shortly.... There may be specs in your owners manual.. This is what I found..
Ignition--5.7 amps (668 watts)
Running--3.2 amps (368 watts)
Actual may be a bit different..
Fraulein
3
quebec
Thank you for the info. I guess this get the Englander out of my list. The Castle pellet stove runs at around 60 watts. This means my battery pack will be able to make the pellet stove run about 6 times longer with a Castle stove than a Harman or a Englander. Now if only I had a Castle pellet stove dealer in my area...🙁
