Powerhorse gen & Harman pellet stove
greywolf46
31
Eastern PA - Lower Bucks
I have a Harman P61a (vintage 2008). Would like to know if anyone has used a Powerhorse generator with a Harman stove. The Powerhorse is not an inverter type, but it has a THD<5. Does this make a difference and would it be Ok to use it? Electricity and electronics are not my thing!
Sorry no one got back to you. We have Yamaha generators here and haven't had to use them yet ... hope it stays that way:) Hopefully this catches attention with a bump to the top of the threads
I run my troybilt generator and power the house, not sure how critical it really is. there seem to be two distinctive points of view on this.
I have a Generac 8500 watt 10000 surge and I power my whole house, knock on wood haven't had to run the stove off of it yet but if I have to I will.
This is a really informative site, Lake Girl - thanks.Thank you all for the replies - it seems that, for Harmans, an inverter gen is the safe way to go - also the expensive way. I was hoping to use a less expensive gen. Someone here said that a gen with THD < 5 would be safe with sensitive electronics. I was trying to verify that from someone's actual experience.
Reactions: Lake Girl
why not just get a sine wave UPS for the Harman and plug that into any working gen? it will address the inverter issue, and provide a smooth transfer between the two via the battery and cover the power spikes.
I picked up a Ryobi refurbished invertor genny for $411from Home Depot and comes with one year warranty. 2200 watt peak
I've often wondered if the Ups will "clean up" the generator power. I have one of the harman recommended ups units and would love to know if I can use my cheap Champion generator so long as I'm going through the ups.
It's my understanding that the Harman recommended units are not sine wave and only provide backup power to allow an emergency shutdown ( thus preventing smoke escaping into a house). Otherwise, the source of power - wall outlet or generator - is passed through to the stove. Wall outlet (from power company) - no problem, but generator, if it's not an inverter, is not "clean" power to the stove. There are Ups units that convert "dirty" to "clean" , but they're much more expensive ($600 +). So, short answer, your Champion will pass its "dirty" power through to your stove. Anyone out there - correct me if I'm wrong.
Reactions: Jason845845
Hey Bioburner how is that Ryobi inverter generator ?
Seems to start on 2nd or third pull even when its sitting in the cold. Have a enclosed trailer for the generators. Give it some exercise weekly as don't want to give anything a chance to fail in this to be a very cold February.
Ran a cord to the Harman in the garage and stove seems to operate without issue and genny hardly knows that its there.
I've got the same generator. I feed it into an APC ups for the electronic stuff. Haven't run the stove off it yet, but if needed I would. Most of my power outages are summer time related, so im using it on my refrigerator, deep freezer, and sump.
Well, a lot depends upon what you mean by "clean". "clean" could mean a pure sine wave. It also could mean keeping the voltage within spec, boosting low voltages and lowering voltage spikes.
Most of the UPSes you hear referred to are APC Smart-UPS, which are pretty basic modified-wave, standby units. When your power goes off, or the voltage goes out of range, like below 75v or above 140v, the UPS takes over.
For a little more money, you can get an AVR, automatic voltage regulator, UPS. They boost low voltages and reduce spiky voltages without switching over to the battery. This can extend your battery life, but it uses a modified sine wave.
And for a little more money than an AVR UPS, you can get a Pure Sine UPS. Those have pure sine waves and typically are AVR too.
I've had at least 4 APC Smart-UPS over the years, usually bought on sale on Black Friday, when you can get an $80 for about $40 at Staples. However, 3 of mine just died in the last year, which made me go looking for something better, like an AVR or Pure Sine model. For APC, those were quite a bit more expensive, so I decided to look at TrippLite and CyberPower.
I found an awesome CyberPower AVR, the AVRG750U, which I use for my computer, which has 12 outlets. I got it at Staples for $45. It's normally $70, but I get a $25 off $75 coupon thru the Staples Rewards program almost every other week via email.
For the pellet stove, I got a Pure Sine model, the CyberPower CP1000PFCLCD. It was $130 at Newegg. There's also a smaller model the 850 for about $115. The LCD display is like having a Kill-a-watt built-in. Tells me how long the stove will run on its current draw. I'm very happy with both units.
Now, you're going to have to test any configuration you go with, because not all UPSes will charge while on generator power. I don't even know if mine will charge, since I haven't had an outage since I got my new UPSes earlier this Fall. Having said that, the input voltage range in the specs is very wide, 78v - 142v, so I'm hopeful. The key will be whether they will accept the modified sine wave coming from the generator.
