The 4500 was quoted somewhere online as the power required for a hot water heater, but my actual heater says 3800 top and bottom.  Looks like there was an option to have 3800 bottom and 4500 top.
S
			S
thinkxingu said:Right, so 3800 watts on a 5500 watt generator should be no problem. As for gas, that's out: I have it at the street, but I'd never recoup the costs associated with changing heating systems. The question is still: what would be the best time to run the h20 heater? At night, after using it, just leave it on because keeping it warm doesn't take as much energy as heating it up?
S
so whats the swithing mechanism which tells top element to burn & not the bottom?Tarmsolo60 said:2 element tanks have only one element at a time operating, the top element always priority over the bottom element. This gives the user faster recovery for useable hot water when the tank is depleted of hot water.
3800 watt elements are for a 20 amp 240 volt circuit
4500 watt elements are for a 30 amp 240 volt circuit
If it were me, I would start the water heater an hour before I need it for showers, then let it run until the load is off the generator after the showers(you should be able to hear that on your generator). That would probably provide you with enough hot water until you start it again an hour before showers the next day.
& so a "quick recovery" is better acheived by fewer watts from 1 element?Tarmsolo60 said:The top thermostat must be satisfied temprature wise before it will transfer power to the bottom thermostat.
ignored this?& so a “quick recovery” is better acheived by fewer watts from 1 element? say so dont make it so! water heater will recover quicker from 2x the wattage, duh, u can reset the thermostats to whatever temp & they"ll react accordingly & INDEPENDENTLY...........your mechanical switching mechanism is yet to be revealed tooTarmsolo60 said:a 2 element (quick recovery) tank will heat the top third of the water heater first to give the user access to hot water faster, then transfer the power to the lower element to heat the remainder of the tank.
If you have a 2 element or a single element tank and the thermostats settings are equal then when both are done heating they will have used the same amount of energy. given the starting water temp, insulation are equal.
The only benefits to a two element tank is giving the user faster access to hot water when the tank is depleted of hot water. Or maybe some access to hot water when the lower elenet burns out.
thanx, new 2me. still, if both elements came on it would heat faster even with this setup, though it might trip the circuit breaker.Tarmsolo60 said:Top thermostat only allows one element to heat at a time.
Qick recovery is better achieved by heating 1/3 of the water to usable temp first.Duh
no way it takes more power to heat a cool tank than to maintain!.........whered u get that?thinkxingu said:Interlock installed, outside outlet installed, water heater changed from second-meter-disconnect to main panel, inspection tomorrow. Inspector said to just leave the H20 heater on when genny running--will not draw like a motor and the rest of the stuff I'll be running (fridge, couple lights, etc.) won't pull enough to tax the generator. Finally, 'it takes more power to heat up a cool tank than it does to maintain a hot one.'
S
