Problem: whitfield prodigy 2 wp-3 6052
stoneyreef
8
Minnesota
Started up the stove today, after I leaf sucked the pipe.
This is my second year burning pellets.
Anyhow stove runs fine EXCEPT: The auger will not feed on the lowest setting. Anyone have any ideas?
Check the voltage to your combustion blower on setting 1. I don't have my book handy but as I recall it should be somewhere around 85 volts. If it is less than 60 you aren't getting enough power to the blower for it to produce the vacuum required and your vacuum switch might be closing. Also the usual check your gaskets, damper settings etc.
