Hi all, so it's -6 here in Ohio this morning and I have a problem. Yesterday evening I noticed the burnpot filled with pellets so I just thought she needed a good cleaning so I shut her down and did just that and fired her back up overnight. I woke up this morning with a super low flame and the house at 47( I run a heat pump for back up only). I've tried shutting it down and cleaning again, I've run with settings 1-4-1 and 3-5-1 which are the settings I typically use at 9-9. I'm running on a skytech wirless t-stat and have checked the batteries in both units. It seems as if either a) I'm not getting enough pellet feed b) the skytech is not working properly to control the stove to set temp. Also, and this may be weird, the stirrer(mixer) motor is running constantly and I could of swore there was a pause every so often to let pellets kind of catch up??? I have had this unit for 5 winters now and this is the first issue other than the 2 ignitors I've replaced. I'm thinking of cleaning one more time and putting the jumper in to bypass the remote to see if that does anything. After that I'm not sure what else to try.I dont have an Englander guy in my area and I have a 5yr old in a bedroom with an Eden pure running. Any help/suggestions would be great! Thanks in advance
Couldn't resist ... got to love auto-correct!
