I'm adding a feed pump to my oil boiler (paralleling with new pellet boiler). Space is tight. It will be pumping to boiler return, and close to the boiler, mounted on a vertical section of pipe, pumping into an elbow which, after it turns, goes several feet horizontally to the boiler. Pipe is 1-1/4", and there are isolation flanges.
Will there be a problem with this? Again, space is tight.
O pump
boiler___________|
O pump
boiler___________|
