Quadrafire Classic Bay 1200i Vacuum Switch/hose help
cb1200i
7
NE
I was hoping someone here can help me diagnose my stove problem.
I have a 5 year old Quadrafire Classic Bay 1200i, installed by the stove dealership, and ran well with no major issues until this week. Use about 4-5 tons a year.
The Combustion (exhaust) fan bearings started to go bad. A replacement is on order, will arrive later this week. The fab completely seized during operation the other night, but the stove still delivered pellets. I shut it down, and all seemed fine. Since the stove is my primary heat source, I was fortunate to find a spare fan from a friend.
Cleaned it up and installed it. Had to reuse his gasket, but it is in good shape. Powered up and the temporary combustion fan ran fine, had the red feed light one, but no pellets. Hit reset to see if that fixed, but to no avail.
So that's my problem. What I've done so far:
Based on some other posts, I checked the vacuum switch. It appears to have power because I can jumper the switch and the unit will deliver pellets. Check the vacuum hose line and tried to blow it out, but to no avail. Can this line get clogged (at the stove side?) I tried some compressed air also (60 lbs), but no luck there either.
What's my next step? I don't know where the other end of the vacuum line is, or how to get to it. If I was able to blow through the line, I would suspect my gasket isn't as good as I thought, but looking there, it doesn't seem to be a leak (Hard to tell with the two external impellers). I also do not believe my exhaust line is blocked to prevent a vacuum, so I'm focusing on the vacuum switch. (hopefully that is correct)
(also, since it is an insert on an elevated hearth, space is kind of tight to trouble shoot: to get to the back, I can't open the hopper lid, and vice versa.)
Any help or guidance is appreciated. Thank you.
If you cannot blow through it it is likely plugged at the stove end, and you just have to get to the end that pierces into the firebox area. Something else and this does not happen on it's own but these are often very soft silicone tubing and I have twice monkeyed around and put a kink in mine and it prevented vacuum from reaching the switch. I think your on the right path. You might try a flash light and a mirror and looking from the front side in the areas the hose is leading to, I bet you can spot it and give it a poke and then re-blow it out from the tubing side so not to contaminate your switch.
Thanks Doug for the quick reply. Just struggling with finding the firebox side: whether I have to go in from the hopper (through the auger recess), from the back (remove sheet metal), or from the firebox side. I was not able to find anything on line that showed how to access is. Due to my set up, I can only try one at a time! Was hoping someone else had the same issue. Never knew how much I liked the pellet stove until it goes down!
Thanks again.
People that utilize a pellet stove as a primary heat source are asking for trouble. It's a space heater, not a primary heat source and shouldn't be treated as such. Don't pressureize the vacuum switch in your effort to relieve the blockage or you'll rupture the diaphragm and render the switch useless.
Reactions: tjnamtiw
If combustion fan was going, your venting may have enough obstruction of built up fly ash in it to create a vacuum problem. Check other gaskets as well (door, ashpan, hopper lid if they have them) that lead to vacuum problems.
Keep us posted!
Reactions: kappel15
You just have to follow the vac hose to where it hooks on a nipple on the back of the drop chute. You need to pull the entire vac hose off and make sure it is clear. Then you need to get a pc. of wire and poke it thru the nipple to make sure it is clear. Lots of times, pellet dust gets sucked into the nipple and hose, and plugs them. I hope you didn't blow through the hose into the vac switch as you may have damaged it. And make sure to follow Lake Girls advice on other vac issues. Let us know how it goes. kap
At one point I determined I was having vacuum issues....I pulled the vacuum switch off the stove and and discovered it was full of fines.....I gently tapped it for a few minutes till no more came out...worked fine ever since.
Reactions: kappel15
Thanks for all your help, the stove is up and running: a solid plug of fine dust in the vacuum line about 3 inches from the auger end.
I should have been more clear on my first post. I removed the vacuum line from the pressure switch end and blew towards the firebox, expecting to see a puff of dust.
I would not have thought to look at the auger for the other end of the vacuum line. Thank you kap.
I didn't fully think of the low exhaust pressure issues (took it for granted that if it was burning, it was venting). Thank you Lake Girl.
And the pellet stove is my supplemental heat, unfortunately my primary is electric baseboard - hence the stove!
This a great community with an incredible wealth of knowledge.
Thank you again for all your time/thoughts/inputs.
Glad you are up and running. Don't worry about primary or supplemental. I use my stove as my primary heat source, and my furnace is my back up. lol Stay warm. kap
Good to hear you found your main trouble . Keep her well tended so she can do the lion's share of the heating job ;)
Thats 'cause you are cheap like most of us....lol Oftentimes, it's good to have another heat source in the backgrouind just in case.....
Ya got that right! I'm so tight I squeak. lol I always have a backup for everything!
