Hi, I'm a long time lurker, first time poster. Usually I've been able to troubleshoot by just searching thru old posts. But this one has me baffled.
Christmas Eve, I noticed that after starting an initial fire, it wouldn't feed any more pellets so that the fire would burn out. I had to hit reset to get any pellets to feed. I kept that up for a awhile but eventually it started feeding on its own as normal and worked fine the rest of the night.
Christmas Day I figured it needed a good cleaning so I turned it off and cleaned everything I knew. Emptied the ash tray. Removed the baffles, vacuumed the fan (and tried to dig/scrape what I could out with my fingers). Cleaned the pipe from the outside (don't know how to clean it from the inside). Scraped the heat tubes. Cleaned lint from the fans and the vents on the back cover. Afterwards, it fired up and worked like a top, so I figured the problem was solved.
4 days later the original problem came back. It stopped dropping pellets so the initial fire went out. I opened it and was jiggling wires a little bit, the one on the vacuum switch was very loose and as I pushed it, it immediately started dropping pellets. So that must of been the problem. I left it running and went to another room where I could research online for a replacement vacuum switch. I read in several places that the glue in them fails and then they don't work reliably, exactly my problem. I was confused for awhile tho because the one on my stove is rectangle but my search only showed me round ones, I guess that's the new replacement part. I was going to order one off amazon but first emailed the seller to ask how difficult replacing it is, being a female, I'm not all that mechanical : ) So while I'm doing this internet research...
The boys come running telling me that the stove is smoking. Sure enough, there was smoke coming from underneath and even drifting through the pellets in the hopper. It got worse as time went on, but it seemed like it was just from the fire in the firepot smothering. I can't remember exactly the symptoms, I'm pretty sure the fan was on. I opened the front door and the smoldering pellets alighted, which seemed to keep the smoke down. So I closed the door again and hoped it was just a fluke.
I let it cool down, dumped the smoldering pellets in the outside fire pit. And started it again. Smoke came again but this time from the ignitor, looking at it, it was coated in black goo that was burning off. And then the fan went off. And the igniter went cold. I think I blew a fuse, possibly blew the ignitor (it's only a couple years old and was working great before), and maybe set off some snap discs.
Now when I plug it in, I get a hum and no fan. The control box flashes 6 times.
I tried to check the fuse on the control box but I can't get it out. I twist it and it only twists a little (1/16th of a turn), I pull and it seem stuck.
I have no idea where the other (??) fuse it. I'm also confused about the snap disks, I think I found 2 (#1 and #3) but #2 eludes me. The manual says it has orange wires and I only see 1 orange wire and in a different place. And it says #2 and #3 have a red reset button and I don't see those anywhere. [Pathetic, huh!!]
So I'd like to fix this myself, but the electronics elude me. I did call the shop we bought it from and they say they don't service my rural area (funny, they sold & installed it for us). I'm waiting for the manager to call back with how much the extra fee to come out here is. And if they do come out, it'll be at least a week, maybe longer.
So, I'm kicking in my head the idea of getting the parts and trying to fix this. Except I can't get past the fuse and snap disks. I know I need a new vacuum switch and probably a new igniter. I'm wondering what started the smoking, did the faulty vacuum switch cause a snap disk to go off, and then the fan to go off (altho I thought for sure the fan was on when it was smoking). Then the gunky igniter, from the smoke? which caused it to burn out or fail, which caused the fuse to blow (and the igniter and fan to stop instantly)?
Any help (handholding) you can give me or should I just leave this for the experts? The manager was supposed to call me hours ago so I'm thinking I'm getting the run-around from them : (
but I didn't want to leave her hanging....
