ok my sante fe freestanding non insert will not feed pellets. i have just cleaned the exhaust pipes and put silicone back on. i checked snap disk#2 and when i unplug it it shuts off combustion fan. i also checked the vacuum switch and blew through the hose . i also unplugged the vacuum switch and touched the wires together and also checked voltage to the auger motor and i get 45 volts when the switch is on calling for heat and when it is off its about 4 volts. i went to the dealer and got a new auger motor to try and same result no dropping pellets. i also took out the auger motor and got all the pellets out. my burn pot is clean and the holes are clean as well. i cleaned behind the fake bricks (took the right one out and cleaned up into the combustion fan). i do see 6 flashing blue lights when its trying to start. there is heat at the thermocouple. checked all the connections and they are good.
what do you think? ill prob have to have the dealer come out soon if i cant figure it out, he said he would take the auger motor back if it didnt solve the problem.
