I have a Quadrafire Castille Pellet insert. I have changed the tadpole gasket on the front door a few years ago(followed a Youtube videop) and I am ready to change it again. While looking at the gasket the gasket does not go across the bottom of the door. Only the 2 sides and the top. This is the way I installed it previously per the Youtube video and did not really think much of it at the time. Should this gasket go across the bottom as well? I would assume it should as with no gasket there, the bottom of the door does not seal at all and I would assume can cause ash/soot etc to leak out the bottom of the front door since there is a large size gap. I attached a picture and marked the area I am questioning. Is it safe to assume the gasket should also run along the bottom of the door? Because the Youtube install video it is not there in that area. .
Thanks
Thanks
