Questions about circulating pumps
mynx
74
Chatham, MI (UP)
Hello. I have a Garn boiler, which works very well. This is my fifth heating season and after dealing with a major leak from the previous owners non-maintenance, it has been problem free. I burn 10 cords a year to heat my home and shop. I consider myself moderately knowledgeable, but by no means an expert. My system is configured so that there is fairly large supply line coming off the top of the boiler tank and running as a loop back to a return line in the bottom of the boiler tank. There is a circulating pump on this loop. This is all within the boiler room itself. There is then a supply and return line off of this that runs through insulated pex to a heat exchanger in my house my house, with the rest of the radiator zones in the house. With the first loop in the boiler room, there is usually a two to 3° difference in the supply versus return temperature and the pump is set on high. If I slow it down, the temperature gradient widens. my question is, what would be the ideal speed? Again, I have no problems with the pump set on high. I don’t know the science around optimizing speed my question is how do you know if a pump is working? This is specifically in relation to , a circulating pump I have on a short loop between the bottom and top of the tank running through a filter. I have a pressure gauge after the pump and before the filter that is always add zero and doesn’t fluctuate with during the pump upper down or actually turn it off. I have replaced the gauge once and this is a fairly high-quality gauge. So I’m not even sure if the pump is running. It is warm of course because it is, running water through the boiler. I hope these aren’t stupid questions, but I just cannot figure the answers out. Thanks.
For my oil and gas boilers that heat baseboards and radiators:
I don't know what circulator you have but on my oil boiler you can see my B&G 100 series spinning when it's on.
On my taco's in other houses you can't see them spinning but can hear a slight humming.
You can also hear them kick on and off when adjusting the thermostat.
Not sure the differences in these circulators vs your Garn boiler set up?
Buy a Rotation Tester and AC Detector for Circulating Pumps etc
Amazon has them for $12
At the larger HVAC shows you can find them for free as merchandizing
Like AHR Expo 2026
NOTE: This tool does not work for ECM circulators
[Hearth.com] Questions about circulating pumps
Reactions: sloeffle
I had my filter set up on my Garn a little different as when mine was built they didn't put filters on them. I pulled the water out of the front of the Garn on the bottom at a T were the drain in the front is. My pump for the filter was right there then piped threw the filter and then returned to the back of the Garn to the top pipe back into the Garn. I had a low pressure gauge before and after the filter and normal had two to three PSI showing on the inlet gauge. I always ran the pump on low and you would have no problem grabbing the pipe and being able to tell the pump was flowing. I ran the pump 24/7 and only shut it off to change filter and would have to bleed it or it would air lock and not flow.
Thanks - super helpful! . I am pulling water off the bottom like you - it re-enters at the top on the front. I like pre- and post filtef guage idea!
I have concluded that the pump is shot. How did i get here? It is red hot to the touch and making funny noises. It is a Taco brand (now a hot taco). Most of my others are B and G. Any preferences on brand quality?this pump is less than 3 yrs old. Thanks!
My geo has two Grundfos pumps and they are 11 maybe 12 years old, and my OWB has two Grundfos pumps on them that are 3 years old. All pumps are still working as expected.
My taco's (007 - f5) (i believe) has lasted a very long time on my gas boiler at my rental. Probable going over 20 years so far.
Thanks. Not sure why mine crapped out so soon. I wonder if it got airlocked and just burned up. I have a vent in the loop and the static water pressure is vertical but who knows. I will try again. Thanks for the help.
maybe a blocked check valve.
I had this on my own boiler in September last year
I have had good luck with Taco and Grundfos pumps. Make sure when you change your filter you get the air out of that loop. I always had to bleed my filter loop or it would be air locked. You can touch the filter housing you will know real quick if its flowing water or not.
14 years on Grundfos pumps in my system
Reactions: sloeffle
Thanks for the feedback - i am going to replace the pump with a taco 0015e3. At $0.22/kWh, I will save about $55 per year on electricity. I am going to havevto prive out the savings for my other non ecm continuous-run pumps
Update: I replaced the pump with a new taco 0015 E3. I disassembled the old pump and it was completely seized up. There were chunks of crud in the pump body, presumably from the bottom of my tank. I would love to put an in-line filter ahead of the pump, but my plumbing just doesn’t have room for it. I plan on running the pump on the lowest setting. As an aside, the new pump seems to be higher quality than the old pump which was a 007 series.
The Taco in the picture was installed in 2006 and has run 24/7 since then its getting pretty noisy but keeps working !
  • [Hearth.com] Questions about circulating pumps
