Hello all:
I am preparing to install a new WoodPro WS-TS-2000 in my home and I am looking for some thought and advice from the more knowledgeable folks in regards to my hearth and heat shield.
In addition to the stove, I think the only other important pieces of information are:
1) I have 9 foot ceilings
2) The room where it will be installed has a slab floor (I do understand I can install directly on the slab, but I do want to raise the hearth between 12 and 14" off the ground).
I have done some research and this is what I am planning to do:
1) Build a 2x6 wood frame and 14.5" on center (Hearth to be 66" x 58")
2) Screw the frame into the wall studs
3) Cover the frame with 2 sheets of 1/2 cement board
4) Cover the cement board with 16x8x4 solid concrete blocks
As for the heat shield, I am planning on the following:
1) Using metal furring channel to create the 1" space between the current wall.
2) Screw cement board into the furring channel
3) Screw fiber cement board (the kind used for housing siding) to the cement board
4) Trim it out with fiber cement board trim
5) Paint it with high temperature paint
My specific questions are as follows:
1) Does the frame as outlined seem adequate to support the stove and block?
2) Does the frame as outlined seem adequate to create the necessary R and K value (R1.19 K0.84)
3) Instead of using 2x6's, could I essentially make the same frame out of cinder blocks (The type used for basements)
4) Is the fiber cement board safe to use as described?
5) Are there any known issues with using high temperature paint in such a setting?
Any other comment or answers to any all portions of my design are appreciated.
Thank you,
John
Thank you,
John
	![[Hearth.com] Raised Hearth [Hearth.com] Raised Hearth](https://www.hearth.com/talk/data/attachments/190/190575-828987fbe9493148fef321b1c3fadd33.jpg?hash=pDCbypke6A)
![[Hearth.com] Raised Hearth [Hearth.com] Raised Hearth](https://www.hearth.com/talk/data/attachments/190/190576-b8f85819b803e44544517271fb940fa1.jpg?hash=k2le9SMH4W)
![[Hearth.com] Raised Hearth [Hearth.com] Raised Hearth](https://www.hearth.com/talk/data/attachments/190/190577-e3dded06e5655d0ce5e5fbab77255549.jpg?hash=I0dEQxDg95)
![[Hearth.com] Raised Hearth [Hearth.com] Raised Hearth](https://www.hearth.com/talk/data/attachments/190/190578-fe97b83ac1ca9102d128513242f3b698.jpg?hash=6JV_MYf88S)
