Raveli not going higher than 66
Davew37529
22
Macungie, PA
The last couple weeks it hasn’t been bitterly cold and the stove is not burning hotter than 66. Last year it would heat us out of the house. I just did a complete deep clean including all the traps at the bottom and the tee. Took the room blower out and cleaned that. I am burning easy blaze softwoods and have all my settings the same as last year. I’m at a loss. The stove is one year and a month old. Any thoughts are appreciated. Thanks
I assume you don't have any daily timer set. Have you tried cracking the temperature up to 70 to see if it goes higher?
Have you compared the temperature that the stove displays, versus a separate room air thermometer? Sometimes the Ravelli room temperature probe starts to go bad, and then the displayed temperature is off by 5 to 20 degrees.
