For some reason ( like I was the other side of the pond at the time ) I forgot my 'in depth' annual clean last year.
The consequences you all know so well !
To compensate I 'added air' - you can choose a figure between -5 and +5 . These are not percents : +5 means around +18%.
This way I was hoping I would last out the season.
I failed by about a week. Murphy at work !
The RDS system , which I have not got , would have tried to do this automatically.
Trying to keep the airflow to the burnpot at the correct level , where my stove just keeps the exhaust fan at an 'appropriate' power level.
As the air passages silt up the airflow lessens . ( in my extreme case to the point where the airflow around the igniter is not enough to set the pellets on fire )
So when I was cleaning it ( and I have never seen those air passages so clogged up ) I changed the programmed exhaust fan settings to reflect the situation before I was forced to clean everything. I then changed the conpensation back to '-5' : so I'm back where I started.
The stove will last over 5 days in this very clean state.
However , when the stove start to need cleaning more often , I can change the compensation to ' -4' .
And so on , during the next season.
Will this work ? Or will Muphy win again ?
