I have no experience with that truck, but after doing an engine job on a Nissan Altima, I would NEVER get a Nissan myself, nor will I ever work on one again! EVERYTHING about doing the engine job was a real PITA! EVERYTHING was hard to get to, lots of sharp edges everywhere, and it was impossible to get the engine out the top! After fighting with it for  too long, had to get it to a shop with a lift so I could take the whole cradle out the bottom to do the engine swing.
It's just as bad as having to remove a cab on a Ford truck to do a turbo or any other major engine work. The manufacturers just don't seem to give a damn about those who want to do their own repair work. I like  Ford Trucks, but would never buy and of the newer ones because of the rediculous requirement of having to pull the cab to do engine work. AND, ever since they "Updated" the 7.3 in 1998 the diesel has been a POS, which was made even worse when the 6 Litre came out.
A '97 7.3L Diesel was one of the best trucks they ever made, but it still had one major flaw (the auto trans) and since then Ford has still not gotten the anal craniotomy necessary to design anything even remotely desirable for those of us who like to do our own work. The problem with the E4OD trans (better know as the E4-Oh-No!) is that it was a modified C-6 (3-speed) that was doomed from the start by extremely poor design. It was never really fixed until the aftermarket took it upon themselves to rectify the situation. So, a properly rebuilt one will solve this trannys ills, but beware the mods necessary are extensive. The pioneer on this one was Jim Galatioto of ATO transmissions in California - Jim is one of those rare auto tranny wizards who really knows his stuff. After he's done with an E4OD the operating temp stays safely in the 150 degree range. Before Jims work these things normally run in the 250 degree range and are doomed to failure by design!
I do not apologize for my frankness because I'm just stating facts!
We need a durable, tough diesel truck that can work!, and work hard without wimping out. We don't need some sissy thing that goes fast but can't pull a wet noodle out of its own ........., and constantly breaks down in the process. You get the idea!
Let's see, who else is there?
Chevy/GMC? Well the Duramax (Isuzu engine) with the Allison Automatic is a great drivetrain, but I can't say I have much repair experience with them, and traditionally the Chevy part of the equation has not given us great vehicles. The Allison trans is unquestionably the best automatic trans on the market, and, as long as you beef it up (if you hot rod the engine) - no worries. In stock form, as long as the engine is stock as well, they are basically bulletproof.
Toyota Trucks ......... that's a real Oxymoron! No real man drives a Toyota, let alone one of what they call a truck! Calling one of their vehicles a truck is just an insult. Try hauling anything of any significance with one of those heaps and sorry, but it just won't do it, and that is if the brake calipers don't sieze up first, or the frame rails don't rot away from under it! They do a good job of "buying" owner loyalty by paying for out of warranty repairs, but when I need to do a job I just can't see trying to do it with the wrong tool: In other words, you don't cut a 24" diameter tree down with a coping saw, so why would you do anything but get a few bags of groceries with a Toyota "Truck"?  Just not a good choice of equipment!
Dodge?
Hmmm, the Cummins engine is phenomenal, but up until only the most recent few years, the quality of the truck was horrendous. Basically the truck would fall apart around the engine! Since about 2006 things have gotten much better and I might even consider one if the price was reasonable! The only remaining "issue" is the auto trans. Dodge doesn't seem to be able to build an automatic that works (How many years have they been building Caravans?, and the auto trans in those things is still a P.O.S. that doesn't hold up). They've had the Ford disease with respect to truck trannys, seemingly up until the new automatic they are using behind the Cummins. It (an Allison copy) is supposedly a good trans, but again I have no experience with them.
So, what is the answer? If what you are looking for is a real work truck and not just a wuss-mobile you basically have to either fork over a boat load of money, for something new with a long warranty in an attempt to protect yourself from expensive breakdowns (and forget about doing your own service) or build it yourself!
It's getting harder & harder to find a nice clean late 90s vintage Ford or Dodge (Cummins with an inline injection pump), but that's a good starting point. My preference is the Ford, but even a beefed-up E4OD tranny (automatics are the ONLY way to go), is a compromise. The better plan is to invest the money you would have spent on the E4OD, into an Allison 2000 series trans swap.
(continued)
