I'm hoping to tackle my hearth this weekend. Basically I only need ember protection, but I'm going to put down at least one 1/2 sheet of Durock and then do tiles on top of this.
Right now I have 1/2 to 3/4 inch of plywood and then 3/4 inch particle board followed by the padding and carpeting. My thinking was to remove the pad and carpeting. Screw the Durock into the underlayment with a boat-load of screws and use latex-added thinset for the tiles.
Questions:
1) Should I remove the particle board and replace it with plywood or is this a non-issue? One fellow that I spoke with said he thought I should remove the particle board in case moisture gets to it, causing it to swell and crack the tiles . . . but then again he also admitted that he has always laid tile directly to plywood and has only used cement board when working in bathrooms.
2) Is there a better way of securing the Durock or is screwing it down to the subfloor OK?
3) Is there anything else I should be doing . . . or doing differently?
As always, thank you for your advice.
Questions:
