Heya,
Just got a new Regency 5100.
It was installed 2 weeks ago in our basement.
The basement has a center chimney stack with 8" flue.
The stove pipe from the stove top to the chimney stack starts with a 45 degree elbow immediately on top of the stove to reach up and over to the chimney stack which is offset from the stove center position. The pipe then rises for 42 inches at a 45 degree angle before it terminates into the chimney stack by way of a 90 degree elbow.
The stove has been running fine, but in reading the manual I see two problems.
#1 In the manual it states the stove pipe should rise 36 inches before using any elbow.
#2 The manual also states that double-wall stove pipe must be used.
I contacted the dealer and the dealer agrees double wall should have been used.
The dealer said they contacted Regency and that they stated the 45 degree elbow on top of the stove is fine and satisfies the 36" rise requirement before any elbow.
If we were to change to a straight run vertical and then 90 degree over to the stack and then another 90 degree to turn into the stack, then we'd only have 34 inches rise.
Sounds fishy to me.
Thoughts from the salty wood stove folks here would be appreciated.
Thanks!
Here's a picture of how it is currently installed.
![[Hearth.com] Regency 5100 stove pipe questions... [Hearth.com] Regency 5100 stove pipe questions...](https://www.hearth.com/talk/data/attachments/115/115092-1bcaf4878a26da6ea425b3e522f0ebd4.jpg?hash=vKngN8TJXS)
Sounds fishy to me.
Thanks!
