Replaced low limit switch now the fan stays on all the time. Jamestown J1000 manual model.
SwampLife
37
Mojave Desert
I had a low-limit switch issue (proof of fire). The Auger would stop feeding because the fire was not being perceived. I jumped the low-limit switch and it worked. I was careful while doing this.
I've installed the new low-limit switch and the fan stays on continuously. I can't imagine what it would be as nothing has changed. It was operating as it should before the switch replacement.
When I jumped the switch the fan would stay on all the time but I figured it was because I jumped the switch.
I think it might be the switch I got because the fan stops when it's unplugged.
Turns out I accidentally ordered a high-limit switch! Problem solved.
Any help is appreciated.
Reactions: ARC
That would do it
Nice to see someone own up to their own mistakes
That would do it
Thanks. It was kind of a relief.
I wanted to leave the post as the simplest things can be the problem. :)
I ended up replacing the high-limit switch (putting it in the correct position) because the original was on there still and figured it's bound to fail.
Reactions: ARC
