This is our first year running this wood furnace, a Brunco WC190 installed in the basement of a new-to-us ~2800sqft 2 story cathedral ceiling home. About 32' of new 8" duravent up the side. After speculation that the rope gaskets on the load and ash doors had lost their seal (hard), I replaced them yesterday. Instantly noticed it was using about 3 times less wood to hold the same temperature. Also has a much smoother operation profile. It used to ramp up quickly, even with low intake air shutter and inducer off.
I just burned all night on 6 barkless, white oak slabs. These are from a veneer plant, cut and split for 3 years, reading 14-16% moisture on a fresh split, at room temperature (stored inside about a week now). So they are dry. Normally I burn veneer blocking or cut, split wood overnight, but this was an experiment using the thinner, hotter pieces.
Normally in these outdoor conditions (low wind, 35F overnight), the 1st floor temperature would ramp from 72F to 76F in 2 hours, then die in about 2 more hours, and that s with about 3 times as much wood in. Last night it held 70F for 7 hours and had a good few coals left, but I noticed the door was covered in fresh creosote, the bad, wet looking kind. I spent an hour with wire wheels on the doors yesterday, so I know they were clean.
I really like the way this operates now but do I have to open the intake back up and increase the thermostat to the blower to keep the creosote in check? Just have a hot burn everyday? Any alternatives are appreciated!
First photo shows burning with the old gasket. 2nd is temp just after adding new splits this morning, next inside of load door, next is load deck where creosote dripped. Blurry because I didn't think to take them until a bit after adding and smoke was coming out.
Thanks all.
![[Hearth.com] Replaced rope gaskets, now creosote? (pics) [Hearth.com] Replaced rope gaskets, now creosote? (pics)](https://www.hearth.com/talk/data/attachments/306/306469-01170042e2342588d39145e2a33438c2.jpg?hash=mlTrCfT5Q5)
Thanks all.
![[Hearth.com] Replaced rope gaskets, now creosote? (pics) [Hearth.com] Replaced rope gaskets, now creosote? (pics)](https://www.hearth.com/talk/data/attachments/306/306505-e6d61b418da1d37a972a267534657f1d.jpg?hash=RNh8nn9dmW)
![[Hearth.com] Replaced rope gaskets, now creosote? (pics) [Hearth.com] Replaced rope gaskets, now creosote? (pics)](https://www.hearth.com/talk/data/attachments/306/306506-643402c1e1481ef46a835515a973d986.jpg?hash=f3DbDtuMB8)
![[Hearth.com] Replaced rope gaskets, now creosote? (pics) [Hearth.com] Replaced rope gaskets, now creosote? (pics)](https://www.hearth.com/talk/data/attachments/306/306508-5854cf8cd85a9f3e61a08f8228bfd612.jpg?hash=P2kNhinFWd)
![[Hearth.com] Replaced rope gaskets, now creosote? (pics) [Hearth.com] Replaced rope gaskets, now creosote? (pics)](https://www.hearth.com/talk/data/attachments/306/306510-5f265eac18eb03b61f2f605ca419bd00.jpg?hash=sWsoLPA89s)
