Rope gasket replacement P-68
Quick question: I have a kit to replace the door rope gasket on my P-68. The kit says I should allow the adhesive to cure for about 2 hours with the door closed after the rope is in place. My question is, can the stove be running while the adhesive is curing, or must the stove be cool? Thanks!
bogieb
2,792
South Central NH
If you are supposed to wet dampen the rope before adhering, I would make sure it was a cold stove (to allow time to dry). What kind of cement is it? You might get better answers with that info.
